JBL 4345 Studio Monitors
JohnRoy
2
JBL 4345 Studio Monitors $5600 usd
I'm offering my vintage loudspeakers, complete original including its drivers and crossovers.
The cabinets, grilles, networks, selector switches, attenuators, screws, clamps, badges, dowels, acoustic lenses, cones, dust caps, voice coils, spiders, surrounds, etc.,
The JBL 4345 is the only studio monitor from JBL featuring an 18-inch woofer - the 2245H provides a rich, deep low-range that is not comparable to a 15-inch woofer (JBL 4333, JBL 4343, JBL 4344, etc.), especially at low-level listening."
For low-pass: 46cm cone type (2245H)
For inside low-pass: 25cm cone type (2122H)
For mid-high ranges: Horn type (2420+2307+2308)
For high regions: Ring type (2405)
Frequency characteristic: 32Hz-20kHz±3dB
Directivity (horizontal x vertical): 60 degrees x 30 degrees (-3dB, 16kHz)
Output sound pressure level: 95dB/W/m
Impedance: 8ohms
Allowable input:
120W (at the time of a network)
200W (multi-amplifier Lo)
100W (multi-amplifier Hi)
Cross over frequency:
320Hz, 1.3kHz, 10kHz (at the time of a network)
290Hz, 18dB / oct (at the time of multi-amplifier)
Enclosure dimension:
253L (Woofer)
14L (mid Woofer)
Dimensions: Width 765x height 1096x depth of 470mm
Weight: 140kg (at the time of an packaging)
jroy6875@gmail.com
