I just learned that LampizatOr makes a power conditioner, the Kraftwerk-10.
MAIN PARAMETERS:
Dimensions:
440mm [W] x 505 mm [D] x 180 mm [H]
Weight 10kg (net)
Copper version weight 11kg
Number of individually filtered outlets: 8
Number of non-filtered outlets 2 with DC blocking
DC blocked are 4 of the 8 filtered outputs and both unfiltered outputs
Max current per each filtered output: 10A or 2300 W
Max current per each unfiltered output: 10A or 2300 W
Max summary load current: 16A or 2,3 kW
No fuses, no switches.
MAIN PARAMETERS:
Dimensions:
Weight 10kg (net)
