I have tried Revopods under a dozen+ pieces of gear.
They definitely open up the sound. BUT I always experienced a bit of the highs being tilted up which sometimes was a bit much (to be fair I a sensitive to high frequencies). I found when matching them with the Well-Float boards it was a better combo to my personal tastes.
RevOpods are great - just make sure you are able to return them if you don't like them.
I have since moved on from them over the last several years. However they do work great for a lot of people. It's just my personal opinion.
I'm getting the best sound out of the Graphite Audio IC-35 Premium feet. I also tried the CLASSIC 100 platform and it is excellent as well.What do you prefer now?
Everyone knows I am a big advocate for Center Stage footers and CMS racks. You might want to consider those Patrick . You might be surprisedHas anyone tried RevOPods or similar under their Lampi Horizon or other Lampizator?
I saw those under your DAC. They also fit quite nicely compared to the RevOPods.Everyone knows I am a big advocate for Center Stage footers and CMS racks. You might want to consider those Patrick . You might be surprised
I should have taken up handball. I'd get a better workout and save a ton!CMS and Center Stage function as a system
If a component sits on eight footers, how do you tune each one under the same component?it is important to 'tune' the RevOpods carefully by ear; they are not plug and play.
here is my post with pictures about that from Feb 22'. in my case it's wearing shorts with no t-shirt and playing a game of twister behind your gear as it's a workout. but at the end it was worth it. then when i added the Server Power Supply had to do it again, and when i installed my Massif Audio racks last year i had to go through this process again for all the Wadax chassis. OTOH once dialed in they seem to stay that way.If a component sits on eight footers, how do you tune each one under the same component?
holy mother of god! the decay now goes on forever (if it's on the recording).
took me about 3 hours to install and adjust the 24 RevOpods (6 sets) under the dac, 2 power supplies and server. had to remove my dart pre so i could remove the 'Tana' Daiza under it to allow for the height for the server to stay in it's spot so i can see the cover art. followed 'Stereophonic's' coaching (thanks!) and bottomed each pod, installed them on the chassis, then reversed 5 clicks. once in place i adjusted each footer by feel to have equal pressure. had to play around some as each footer is relational to all the others, so you are going around adjusting them all little by little until all of them are as equal feeling of pressure as possible. i will give it a week then go back and check and adjust them again. not really that hard other than in behind the middle of my rack it's a bit of a twister game for my 'old' body. handled the weight ok with no mishaps. took my time.
i was able to combine the RevOpods with the Dazia on the dac and power supplies. but have not A/B'd it so cannot speak to the significance. not sure i will bother with that (hearing zero compromises in any case, likely helping).
RevOpods are the real deal! at least in my system under the Wadax Ref dac and server. immediate sense of more holographic and microdynamic presentation. noticeably greater emotive and expressive content, greater harmonic complexity and textures. greater coherence and drive, more feeling of ensemble playing and flow. lots of small differences musically helpful.
just starting to explore more music and discover the nuggets of ROI. looking for some bass heavy tracks.
and we know what 'black chrome' looks like! perfect match for my chassis color scheme.<<<<<<
for the large 100 pound Wadax Chassis (Level 4 Wadax includes 3 such chassis) with it's unusual 'H' shape, having 8 footers is optimal as long as the height and tension is tuned to be equal for effective decoupling. rack surfaces (or in my case the panzerholtz Daiza top surface) are not always perfectly flat and level. so tuning tension by hand is important. i could hear the difference before and after i adjusted the height and tension.I did all that. Also sometimes using LESS RevOpods on a unit rather than more yielded better results.
By 'tension' I assume you mean compression, or weight on each footer. How are you measuring this - strain gauge?for the large 100 pound Wadax Chassis (Level 4 Wadax includes 3 such chassis) with it's unusual 'H' shape, having 8 footers is optimal as long as the height and tension is tuned to be equal for effective decoupling. rack surfaces (or in my case the panzerholtz Daiza top surface) are not always perfectly flat and level. so tuning tension by hand is important. i could hear the difference before and after i adjusted the height and tension.
agree that for conventional rectangle chassis shapes that it's more reasonable to experiment and listen and be open to what works.
you have already made some adjustments in the gap in the footer body the same for each. all that is left is the height issue.By 'tension' I assume you mean compression, or weight on each footer. How are you measuring this - strain gauge?
