Ok you guys that are using an external pre with your Studers, where do you have your pre located???
Jay
Jay
Do you have a pic?I have my studer on horizontal position and Repro just ahead of the Studer connected to a short interconnect
Mike where are the pic's???
Jay
Jay, sorry how do u post photos?
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typingafter it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.![]()
here ya go! (please excuse my lame photographic skills).
the line up....
the King-Cello. the top box is the repro, the bottom the power supply. sitting in front of the top box is a Wave Kinetics A10-U8 decoupling footer. there are 4 under the head unit. i added the smaller Walker lead filled pucks to get it to 'hook up' better with the footers.
under the power supply are the large Walker brass spikes, and on top are the large Walker lead-filled pucks that dampen the reasonance from the box.
the stand is a $25 plant stand i had sitting around that fit in the space.
it sounds wonderful.
the head switch on the A820. you can see the 'Ki Choi super-nuclear' cable snakeing between the reels over the back of the Studer....
the 8 meter BNC 'Zeel' cable tucked into the seam between the hardwood and carpet. this gets rid of the damn XLR's laying across my carpet.....and sounds much better too.
Hi Sam,
Yes he is very good at what he does probably the best, at least that I know. He did an excellent job on my headblock all I had to do was run the wire in my deck an make the connection. My friend Brad of did that work for me, took him about 15 min. Now I have the option of using the Studer electronics or the Tube Repro from Bottlehead.
Jay
Here is what I did for my Studer and Otari decks, a simple shelf that took about 15 min. to cut out. A couple coats of paint and there you have it!!!
Jay
