Meet the iFi AUDIO micro iDSD Signature Finale
AMR / iFi audio
2,635
1,048
260
44
UK
ifi-audio.com
Meet the iFi AUDIO micro iDSD Signature Finale​
Portable Headphone Amp and DAC, Adorama Exclusive
Available only on Adorama: iFi AUDIO micro iDSD Finale
Key Features​
  • Cutting-edge 16-Core XMOS technology for flawless MQA decoding
  • Enhanced volume knob for precise control, minimizing imbalances
  • Upgraded ELNA Audio capacitor for superior performance
  • Striking FINALE titanium grey chassis design
  • Versatile audio options tailored to personal preferences
  • Industry-leading Burr-Brown MultiBit DAC chips
  • Compatible with Hi-Res Audio for a premium listening experience
  • 3D+ Holographic feature for immersive soundstage
Top-of-the-range desktop/transportable DAC and headphone amp will supercharge your tunes.​
Out of this world​
Sporting a Space Blue finish and powered by a built-in rechargeable battery, the micro iDSD Signature is a transportable DAC/headphone amp that’s ready for anything that the universe throws at it.
Battery power means it’s ultra-clean with ultra-stable DC power and avoids the pitfalls of AC mains – dips, spike and noise-inducing RFI/EMI pollution.
And with up to 12 hours playing time, depending on the headphones and performance mode engaged, it feels like you could take it to the moon and back.
Finely tuned​
Based around two Burr-Brown DAC chips in a custom ‘interleaved’ configuration, the digital engine has four pairs of differential signals – two pairs per channel. This means
  • a lower noise floor
  • improved channel separation
  • finer musical detail and micro-dynamics
The micro iDSD Signature handles up to PCM 768, DSD 512, 2xDXD and MQA. All this is done natively. Both PCM and DSD remain ‘bit-perfect’.
Circuit training​
With up to 4100mW of power the micro iDSD Signature can drive all manner of headphones with aplomb, from highly sensitive in-ear monitors to current hungry planar headphones.
The signal path has been refined to maximise sonic texture. High spec components featuring class-leading qualities such as low ESR (Equivalent Series Resistance), high stability and low distortion mean top-notch sound quality and maximum musical enjoyment.
Add in the direct-coupled nature of the circuit – no coupling capacitor is present – and the micro iDSD Signature definitely runs rings around the competition.
Precision personified​
Extensive jitter-eradication technologies are applied to the digital engine, including iFi’s GMT (Global Master Timing) femto-precision clock and the intelligent memory buffer.
The micro iDSD Signature also comes with iFi’s GTO (Gibbs Transient Optimized) digital filter installed. And exclusive firmware available on our website means you can change digital filters as you wish.
Get connected​
The micro iDSD Signature features two digital audio inputs – USB Type-A and an S/PDIF socket that accepts both electrical, via a 3.5mm connector, and optical signals – adapter supplied.
It also houses a pair of RCA analogue outputs to connect to a pair of powered speakers or a power amp to act as a DAC.
There is a 6.3mm output for headphones that have a standard single-ended connector (headphones with a 3.5mm jack can be connected using an adapter) and a 4.4mm Balanced output for headphones offering our S-Balanced connection.
Both headphone outputs utilise our ‘S-Balanced’ output circuitry. This delivers the sonic benefits of balanced connections with all headphone/earphone types – even those with single-ended connectors – cutting crosstalk and associated distortion in half.
