MIT upgrade help needed,
graystoke4
19
uk nottingham
hi i am going to upgrade my interconnects this year,at the moment i have shotgun MA, just to say i am in England,the shoot out is between MIT matrix oracle 50, MIT oracle v1.3, and a second hand pair of MIT oracle MA-X rev1, these i think are my front runners, as i am in England these are all of a similar price point, i know the MA-X has the most poles, but it is an old model, buying new from the state's means i will be paying 1£ for 1$, not good and i think i will have to pay 22% import duty, any help will be appreciated ,my system is Wilson audio Sasha's mk1, Spectral 30ss s2,Spectral 360 s2, Esoteric x03 se,thanks andy i play mostly anything rock based
The consensus seems to be that the Matrix is better than the V1.3 Range. Personally i disagree with this, as i have always prefered the soundstage and Imaging of the 1,2,3 Line up to the MA / Matrix line which focuses more on Timbral fidelity.
At the end of the day it depends on your personal taste, as these cables are just voiced differently. I can't comment on the MAX- as this is above my paygrade. Mabe you will find that it is the best of both worlds.
Hope this helps
thanks, the trouble is in England it's probably impossible to hear them all together
Hi there, I'd go for the MA-X if it is reasonably priced.
Wim
I had your system driving Magico S5s for some time with Spectral-MIT 350 and 770 UL2 first, and Matrix 50 ic -Rev 90 speaker cables later. The Matrix 50 RCA cables (ran at 5 meters and bought at a set low impedance) were just outstanding. I have not heard the oracle v series. There is a very natural presentation of music the MA50s offers. You will listen for hours on end, and never tire of the detail offered. YMMV as this is IMHO
hi i am going to upgrade my interconnects this year,at the moment i have shotgun MA, just to say i am in England,the shoot out is between MIT matrix oracle 50, MIT oracle v1.3, and a second hand pair of MIT oracle MA-X rev1, these i think are my front runners, as i am in England these are all of a similar price point, i know the MA-X has the most poles, but it is an old model, buying new from the ststes means i will be paying 1£ for 1$, not good and i think i will have to pay 22% import duty, any help will be appreciated ,my system is Wilson audio Sasha's mk1, Spectral 30ss s2,Spectral 360 s2, Esoteric x03 se,thanks andy i play mostly anything rock based
