In the end, nothing is at it seems
Physicists have performed a variation of the famous 200-year-old double-slit experiment that, for the first time, involves "exotic looped trajectories" of photons. These photons travel forward through one slit, then loop around and travel back through another slit, and then sometimes loop around again and travel forward through a third slit.
Interestingly, the contribution of these looped trajectories to the overall interference pattern leads to an apparent deviation from the usual form of the superposition principle. This apparent deviation can be understood as an incorrect application of the superposition principle—once the additional interference between looped and straight trajectories is accounted for, the superposition can be correctly applied.
The team of physicists, led by Omar S. Magaña-Loaiza and Israel De Leon, has published a paper on the new experiment in a recent issue of Nature Communications.
Loops of light
"Our work is the first experimental observation of looped trajectories," De Leon told Phys.org. "Looped trajectories are extremely difficult to detect because of their low probability of occurrence. Previously, researchers had suggested that these exotic trajectories could exist but failed to observe them."
To increase the probability of the occurrence of looped trajectories, the researchers designed a three-slit structure that supports surface plasmons, which the scientists describe as "strongly confined electromagnetic fields that can exist at the surface of metals." The presence of these electromagnetic fields near the three slits increases the contribution of looped trajectories to the overall interference pattern by almost two orders of magnitude.
"We provided a physical explanation that links the probability of these exotic trajectories to the near fields around the slits," De Leon said. "As such, one can increase the strength of near fields around the slits to increase the probability of photons following looped trajectories."
https://phys.org/news/2017-01-physicists-exotic-looped-trajectories-three-slit.html
