RCR filter - can you verify my calculations
ack
May 6, 2010
6,774
1,206
580
Boston, MA
Hi,
you are looking at my Alpha DAC's analog output (J11 is the female RCA, and the bent pin is the positive):
R245/C185/R246 form an RCR filter (and I have verified that the yellow C185 capacitor's "north" lead connects to ground). If the values of the resistors are 75ohms each and the yellow cap's 1nF, I am calculating a roughly 1MHz corner frequency (1.061MHz to be exact), or is it ~2MHz??? My goal is to lower that frequency with the addition of the white 10nF Vishay cap, which should bring the corner frequency down to 96.5kHz, if the stock cutoff is ~1MHz; otherwise I need to add another 10nF
Can someone verify my calculations?
Thanks
-ack
You need to know the driving and load impedances to calculate accurately. Assuming an ideal (0-ohm) source (i.e. U40 is a lo-Z driver) and a hi-Z load then the second resistor in the pi filter is irrelevant and the corner frequency is simply 1 / (2*pi*75*1nF) = 2.122 MHz. Probably to filter out the DAC's clock from the output. The second resistor probably helps isolate the opamp (U40) from the load for both stability and short-circuit protection.
HTH - Don
Thanks Don; I suspected the second resistor might be irrelevant to the filter calculation (BTW, load impedance is 15K), therefore, indeed the corner frequency is then ~2MHz; I am glad I asked. I also suspect the filter is there to attenuate the clock from the output. So as is, the mod's corner frequency is now at ~193kHz, double my goal's, and I think I still want to go lower.
