I have just had 2 very exciting days auditioning the first pair of Sasha Daw in my country.
They are definitely a big step up from my current Coincident Total Victory speakers. The bass, resolution, dynamics are all at another level. The speakers are new and maybe had just several hours of use on them, before they were brought to my apartment. As you can imagine, the first couple of hours the sound was not good at all. Then they started to ease up, and by the end of the first day the normal midrange started to appear. My 18 W Border Patrol SET amplifier drove them quite well, even the WA distributor representative were surprised and admitted it.
My only gripe about the speakers - the midrange still sounded a bit edgy and dry comparing to what I am used to. Maybe, it’s a break-in issue, or maybe it’s the speakers’ neutrality, and I must just get used to it?
Another question I have is the choice between DAW or Alexia 2? Wilson people told me, A2 is more adjustable and could be better adapted to my room. Is that true? Will I gain anything else apart from better adjustability and deeper bass, if I choose A2 over DAW? And finally, is A2 the same relatively easy load to an amplifier, as the DAW? A2 is less sensitive, the minimum impedance is about the same, but strangely enough, the minimum recommended amplifier power is 20 W per channel vs 25 W for Sasha.
Thanks in advance.
Aziz
Thanks in advance.
Aziz
