Sound system for a hall
neilmol2009
1
57
Hi, my friend is hosting some wedding events at a hall and would like to know what would be the best option for a sound system? There's speakers all around the hall but nothing else, they would like something that could read memory cards, plug in a phone, stream from the internet, play a cd, connect to the wifi, it would be great if there was an all in one system with amplifier built in and not too pricey. Thanks
In a hall you will have some issues with the acoustics if not done correctly. Is there a DSP installed? It depends on how big the space is and how many people will be in that hall (acoustics absorption).
My advise is ... get advise from a local pro (maybe a rental company that deals with these situations on a daily basis).
Google PA systems or go to Amazon and search for PA systems, plenty of options available, he has to figure out what's exactly in the hall to know what he needs. If the hall isn't a dump that hasn't been used for a while they should have some type of amplification he can plug in his source into, if not he needs to know how many channels and resistance of speakers to buy an amp.
david
