Speaker recommendation
Ratbastrd
47
11
138
I am unfortunately going through a divorce and a moving to a smaller place. Fortunately, I will be relocating to Southern California and will thus have exposure to many dealers I don't have in my current location.
Am looking to replace the speakers in my system, which I have generally been happy with (Devore Gibbon X's). As I'm expecting to be in a smaller place, I want to try and find a slightly smaller form factor speaker for space reasons. Also ready to move on from the Gibbons for acoustic reasons, see below.
Esthetics are very important to me. Unfortunately, this eliminates much of what I see in market. I just prefer more traditional shaped, natural wood cabinets. My price range is sub $25K (open to used equipment).
Additionally, there are two other aspects to the Gibbons which I want to address. They are spectacular when playing acoustical music (Jazz, classical etc.). They are very transparent and arguably the most realistic sounding speaker I have ever heard (Piano, vocals etc.). The sound stage is quite impressive, at least to me. Problem is (as others have noted) I find them to be rather harsh and underwhelming with music that would typically be listened to at louder volume. I've realized, they just don't move enough air to enjoy music that wants to be played loud, and turning them up only makes it worse. This might be a placement issue, or incompatibilty with the system, but given other reviews I have read, I think it is probably just the nature of the speaker.
My current system: Antipodes K50 > Bricasti M1II > Mark Levinson 585.5 > Devore Fidelity Gibbon X (wired up with full loom of Black Cat Graceline L3). I have some network elements in front of all this to address network degredations. I listen exclusively to digital, either streamed or played locally from an extensive set of files.
So, very curious to get as many recommendations as possible. FYI, I do plan to listen to the new O/96 bronze as well Harbeths, when I get settled in.
My O/96 sound great at loud volumes, reminds me of horn speakers a bit. Definitely try and audition when you're down there, it's available through a few dealers and close enough in house sound if you like your Xs
Reactions: Ratbastrd
You should have quite a few choices. Do you know how big your new listening space will be?
Unfortunately I don't. I know I will be renting for a few years, so likely small condo or a cottage. 12x18??? best guess. Which brings up room dynamics and placement.
You mentioned probably needing something with a smaller form factor so I would recommend considering something like a compact monitor on a stand. Relatively easy to place and move and suitable for a smaller room.
Harbeth is on your list so I would suggest checking out the ProAc line up. They have monitors and slimmer floor standers and most importantly they have a very engaging sound. They should work fine with your electronics.
The Wolf Von Langa Son is a lovely speaker but I am thinking they might not be happy with your present system. I may be wrong though so worth checking them out.
With your emphasis on aesthetics and sound, have a look at the Sonus Faber MaximaAmator. I have a pair. Excellent. Each speaker is made from a walnut block and stands on a slab of Italian marble. They have good bass response down to 35hz. While they can play rather loud, they are 2-way monitors not party speakers. I use a 200 wpc integrated amp to drive them. Very pleasant sound and a delight to see them in the room. They are so simply elegant.
I second Sonus Faber. Just a gut feeling OP will like them. Maxima Amator or Olympica Nova V or Serafino G2. Ironically, not the type of speakers I would choose. But I think going from Devore to Sonus Faber should work great.
For the size of the room I would recommend the Diapason Adamantes V. Excellent workmanship, the bass/midrange driver will operate without xover, only xover for the tweeter. Plays very deep bass for its size. If you get the chance to listen to it, make sure you do so..
Lately, the best bookshelf speakers have been coming from Italy. It doesn't matter whether you use Grandinote, Diapason, Opera or Sonus Faber. I really like the sound.
I live in So Cal, in a place about the size you're looking at. Based on your criteria I would recommend Franco Serblin Accordo Essence. They are like Sonus Faber but with the magic back when Franco was designing Sonus Faber.
Here are some alternatives worth checking:
  • Wilson Audio Sabrina X
    • Smaller form factor
    • High-end performance
    • Several finishes available
  • Joseph Audio Pulsar
    • Compact design
    • Excellent for acoustic music
    • Wood cabinets
    • Good transparency
  • Sonus Faber Olympica Nova II or III
    • Elegant wood design
    • Excellent sound quality
    • Good for both acoustic and more dynamic music
  • Harbeth
    • Traditional design
    • Natural and transparent sound
