Spectral DMA200 bi- amping ?
msm_1
42
1
Hi
I have a Rogue Magnum 99 Pre, a Spectral DMA-200, a VPI Scout with a Koetsu Black, a Classe CD/DVD1 used as a transport with a Classe DAC-1, a Sony cdp-x777es and a Nackamichi Dragon, and a Rotel 1040 Line Conditioner.
I have a 2nd Spectral DMA-200 and am seriously considering bi-amping the pair.
Any ideas as to what I may expect or please give ideas or recommendations?
I'm glad to have found this forum, and glad to be a member
Thanks
Mike
Hi
Thanks
Mike
What speakers are you using?
You should probably expect a more effortless presentation. I believe this is the only pure Class-A amp Spectral has made to date??? Also, since I also used to have a Classe DAC-1 long ago, I can comfortably tell you newer technologies eclipse it in performance.
Thanks....I think the Spectral DMA-100 was a Class A as well. I haven't see my first hydro bill yet, but each DMA-200 eats 1200 watts at idle ( not sure when driving ).
I know the DAC-1 is getting older and have been looking at the new Simaudio Dac and may try one out within the next month.
I'm currently checking out different Pre's that have 2 main balanced outputs so I can hookup my 200's that way. ( possibly a Balanced Audio model )
Thanks
Mike
Hi Mike,
I used to own a DMA 200 but never had two units to use in bi-amp mode. However, about 15 or 16 years ago, I had the privilege to listen to a pair of Entec ribbons bi-amped with two units of Spectral DMA 200 power amps. Etched in my memory was the incredible amount of ambience retrieval the system was able to generate. It was so much that I could hear and feel the ambience bloom all the way between the speakers and my seat. There was also the feel of how the music "surfed" through the ambient field on it's way to my seat.
You should proceed with your intentions on bi-amping your Von Schwiekert VR 4 asap. Off my mind, I would either put a crossover unit between the preamp and power amps or make a balanced Y connector to have the preamp balanced output tap drive both DMA 200 amps at the same time.
I believe the DMA 100 is also a class A amp. My DMA 100 must be more than 20 years old and still works perfectly whenever I insert it into my system.
I hope you post your impressions once you bi-amp your speakers using the two DMA 200 amps. Have fun.
