Suggestions for a Newbie
Jester
1
I have been using an old Marantz 1250 (SS amp) since the late 70's, still works great. I'm thinking of getting a tube amplifier and would like suggestions on a suitable amplifier that will hopefully not break the bank.
I had an audiophile friend back in the 80's that introduced my to the sound of a really good system (from my perspective). The speakers (there were two different sets) one being big flat Magplanars? and the others custom built KEF. Both sounded different but amazing. The power amplifier was tube based, the pre-amp was SS I think but i'm not sure. I would like to recreate that sound.
Once and a while I enjoy cranking up the volume, so I would not want something vastly underpowered compared to my present 2x125W Marantz.
Suggestions and comments please.
I have also Marantz 1200B and sound is good also today
With old Magneplanar you need power,at least 80/100 watt tube so if you need good tube at cheap price has to check in vintage and find old Jadis 80 or ARC d 115,or CJ MV75,or EAR 509
Hi Jester, I understand your feeling. My first audio system that I had back in 1977 was a Panasonic radio & tape recorder one speaker only. Of course I was a young boy and was very happy, now I have 3 audio setups, giving a look at the Bryston 28B3 monos 1,000 watts $22K and I'm not that happy as I was in 1977. I am in a different money situation today as it is expected to be successful in life but going back to your question :D There are lots of amps and speakers to choose from. If you like the KEF signature sound, check their new stuff, listen to them and find a suitable amp for that speaker. I have had KEF with tube and SS amps and sound great depending what music you like. B&W are great also. About Amps there are many tube & SS great amps like Audio Research, Conrad Johhson, Cary, Jolida for SS: Bryston, Krell, Mark Levinson, Parasound, Rotel, PS Audio but the only problem that I have found with all these units is the amount of heat that they develop in the room. If you go with a pure A class amp,100 watts it is enough but if you go with a D or A/B class amp a 300 watts is needed to drive a good number of speakers under $20K.
What is the bank? If it's $6-7K, then I highly recommend these:
http://www.arteformaaudio.com.tw/due-volte.asp
Then you need to roll the tubes. I can help you optimize them if you purchase these amps. PM me.
If you are on a severe budget, get an old Scott EL84 based amp on ebay and roll the tubes in that.
Steve N.
Empirical Audio
Welcome, Jester!
