Hi guys,
I've been working on an active system for a while now. This is a cost no object system, where only the finest methods of handling every aspect will be acceptable. How I have it figured is, the best way an active system can be built with today's technology is by using PC based 64 bit floating point DSP/Room correction/Xover software, combined with a state of the art multichannel DAC such as the Merging NADAC or Hapi. Try finding a DSP chip based system that does 64 bit floating point DSP, is native DSD 256 capable, and has the specs to match a Merging NADAC or Hapi. If your unfamiliar with the NADAC, check out this review, it was the finest DAC David Robinson ever tested out of 300 reviews!
http://positive-feedback.com/audio-discourse/impressions-the-merging-technology-nadac-mc-8-dsd-dac/
And from what I'm told, the Hapi uses the same DAC board.
If your a fan of vinyl, you'll need an A/D converter and phono stage to rip your vinyl to digital with an DSP based system. When you use something like the DEQX, it just does this on the fly with mediocre A/D's. So if you opt for the Hapi, you can add the state of the art A/D board (which is well known to be among the finest A/D on the planet) and rip your vinyl to your PC at up to DSD 256 resolution, and store on your HDD or NAS along with the rest of your digital collection. There is no better possible way you will hear your vinyl today through an active system. Another big bonus is you just have to rip once, and put it in the sleeve to be perfectly preserved with no wear and tear. Think of the wear and tear you'll save on your turn table and cartridge only having to play each record once. And think of the convenience of being able to cue up your vinyl via mobile app. You'll still have the sound of your turntable perfectly preserved, combined with the convenience of mobile app GUI control.
So what's it cost for a full blown system based on the Hapi? Well the Hapi with both DAC and A/D boards is $5800 U.S. If you don't need the A/D, drop $1800 off that.
Then software like Acourate costs $400. Media player software another $150. If you need the A/D section for vinyl ripping, $2000 should get you a pretty decent phono stage. Then all you need is a decent server PC. Well $2000 should buy that.
So just over $10000 for full out native DSD 256 capable analog/digital setup, or $6650 for digital only.
If anybody knows a better way at any price to build an active system, please let me know. As I'm still in the learning process.
Thanks.
Thanks.
