![RT_EBL1_PhilipsEL50.jpg RT_EBL1_PhilipsEL50.jpg](https://www.whatsbestforum.com/data/attachments/135/135694-29c11c61afad13da779bc20e30d73d81.jpg)
Purpose
This thread plans to be an open discussion related to tubes. I am a tube roller interested in their history, pinouts, internal construction and date codes. I also try to measure them using my basic tube tester. I am doing this for several years, started a thread more as a personal blog and free discussion on another forums but since they imposed a limitation on double posting they currently blocked my activities. I have a full time job and only several open slots where I can perform some tube rolling on mostly unknown tube types. I try to expand our knowledge on tubes, to increase my understanding in this area and also to provide a fun place for people interested in the same things as me to discuss and help each other.
My amplifier
The context of my tube rolling is a little bit different that what you will find on other amplifier centric based threads, where people gather to share their impressions based on a specific piece of equipment. I have a custom made Ultrasonic Studios amplifier called Eternity. There are only 2 built in the world and they are somehow unique. This amplifier was built at my request by a very nice and knowledgeable person who is deceased and a part of my work is also dedicated to him. I want to keep his memory alive and share to others a part of his work. Because nobody can describe better the amplifier than the builder himself I will quote him here:
Eternity is basically a low power version of Infinity. A SET, single ended triode, amp with open loop (no gNFB) and parafeed output. The input stage, using the 6AV6 tube, is grid (fixed) biased. Followed by CCS loaded source followers that drive the output tube grids. The grid drivers relieve the input tube of any drive duty. Tubes do only voltage amplification. Tubes do what they do best and FETs do what they do best, supply current. The output stage is also SE and grid biased, using the 6S19P tube. All tube anodes are gyrator loaded. Both B+ and B- supplies are regulated. Eternity, just like Infinity, will have more of the old tube sound than Oblivion and Citadel has. This is because it’s single ended. The balanced amps cancels a lot of distortion and are also constant current draw amps, while Eternity is not. It’s a matter of taste what sound signature you prefer. Eternity can drive efficient speakers as well as headphones. Power output is 3W into 8 ohms. 1W into 8ohms, 430mW into 20 ohms, 170mW into 50 ohms, 90mW into 100 ohms, 45mW into 200 ohms, 30mW into 300 ohms.
I will make some personal remarks about the amplifier. In order to provide more information, my amplifier uses fixed grid biasing, by providing a negative voltage to the tube control grid. My input stage is fixed at Va = 180V and Ik = 4mA with a range of safe operation range of 3-5mA. The output stage is fixed at Va = 200V and Ik = 20 mA with a safe operation range of 15-24mA. This means that every time I will use a tube I will have to measure and pair to keep both tubes from left and right channel in the specified range. I can use almost any tube in this amplifier, as long as I can bias it to keep it in the above mentioned ranges of current. I have 5 sockets, for output stage there are 2 wired for 6V6 and for input stage there are 2 wired for 6J5 where I use in general single triodes or triode strapped tetrodes or pentodes and 1 socket for double triodes wired for 6SN7. In fact, output stage is also triode strapped. Because I was a fan of 6N7 back in the day, I asked the builder to wire 6J5 to be able to natively use 6N7 with both triodes in parallel. The trimmers I have for negative voltage have a limit around -13V for input stage and -55V for output stage. So if a tube requires more I will not be able to bias is and therefore not be able to try it. But even with these limitations I was able to try a broad range of tubes and explored many families already.
Fixed grid biasing and this kind of gyrator loaded plates with source followers made from MOSFETs made my amplifier sound extremely controlled, neutral and clean. It is a low distorted design which does not necessarily sound tubey. So my remarks during tube rolling will be mostly made in this context. Last but not least, it is a headphone only build, without any output sockets. Besides this, I have a very bad taste on music, I am a Black Sabbath and Slayer fan. So unfortunately I will not be able to provide many useful information to elf eared audiophile people.
People interested in finding more can look here, they can see some nice photos and also a part of my past activities. Apologies in advance for the amount of spam, I also consider that some of the discussions were interesting. Looking back I think the magic of the thread was the bunch of people from different backgrounds and using different amplifier which provided common findings. Some listened to speakers, others to headphones, some were Lampi users but we all found common ground in our common love: tubes.
Let's start!
I am new around, 2 days ago I searched for a forum where people are interested in tubes where I could continue my discussion. I was pleasantly impressed by the tube collection of mr. Adrian Cheng and thought here I might find some partners in crime which will help me explore the unknown world of tubes. Help me understand more, listen to more and why now, explore more unknown tube types. Unlike him, I am not a collector, I own many tubes but a big part of them are unkown types which are not valuable. As we know the tube value is dictated by fame and rarity. My war is not to own the rarest of ones, but to find the cheapest unknown types and to bring them back to glory in my small and unique amplifier.
I am Mr. Miniwatt and I welcome all of you here to discuss about tubes.
