Turntable problem tick sound
Hello guys, i have a problem you can hear in the video. It seems cause this part is a bit loose. How can I tighten it? Or maybe it's something else? Any ideas? Video:https://streamable.com/8px4mh
You have a bad motor bearing or a crooked motor shaft, I don't know which turntable this is but some motors you can open up and change out the strike pad nothing you can do with a bent shaft.
david
