Hi there,
I work at an auditorium that currently uses the Beyerdynamic Opus 600 Wireless Microphone System. Our setup is as follows:
- an unknown number of antennas above the stage or elswhere in the auditorium
- 1 UHF Antenna Splitter (Opus ZAS 800)
- 3 UHF True Diversity Receiver (Opus NE 600 D) connected to a Yamaha LS9-32 digital mixing console
- 5 BeltPack Transmitters (Opus TS 600), with Beyerdynamic TG H54c microphones
We are experiencing two types of problems:
a) Some microphones only pick up the sound when very close (~5cm) to the mouth. Sometimes, the same microphones can pick up the sound, although intermittently, when located farther from the mouth.
b) When there are two microphones on stage, usually 3 feet apart, there is a very loud high pitched constant buzzing noise.
Why is this happening, what could we do pinpoint what isn't working correctly and how could we fix these problems?
Thank you,
shipsandtides
Thank you,
shipsandtides
