XACT Immotus – Game-Changing Anti-Vibration Footers
Marcin_gps
Manufacturer
Jun 24, 2015
321
332
525
jcat.eu
Hey fellow audiophiles,
If you’re looking for a serious upgrade in vibration isolation, you might want to check out the new XACT Immotus Series. These mechanical footers are designed to eliminate internal vibrations that affect clarity, detail, and bass precision—something often overlooked in high-end setups.
XACT Immotus CL – Aerospace-grade aluminum, single-layer bearing, precise focus & resolution.
XACT Immotus CRX – Copper alloy, dual-layer bearing, unmatched stereo imaging & bass articulation.
High Fidelity recently tested the XACT Immotus footers, and the results speak for themselves:
“Turbocharger of our emotions accompanying music listening. Sitting down in front of a good audio system with both types of feet we’ve been talking about, we allow the music to possess us, to take us elsewhere….” – Wojciech Pacula, High Fidelity
Full review here: https://www.highfidelity.pl/@main-1437&lang=en
More details on XACT website: https://xact.audio/immotus-footers/
Link to the webshop: https://jcat.eu/xact-audio/
Reactions: kyoya78 and keithc
I cannot find the dimensions for the units on your website or on the review. Can you please provide?
Is there a "minimum component weight"? In other words, have you tested it on lighter components such as some switches, smaller PSUs, etc., and found that components below a certain weight do not benefit?
Hi Keith,
Here are the dimensions in mm:
There is no minimum. The footers work well with any component. Currently I have CRX under all components in my system including ULTIMO PSU which powers a clock for Esoteric Grandioso K1XSE DAC/player. The effect is consistent with any component.
If I have to choose the most effective places to use them it would be:
- under speakers (I can't imagine removing them from under my YG Hailey 3)
- under DAC & streamer
- under power distributor
Best regards,
Marcin
