Finite Element Classic footers.
High End-Entkopplung für Audio-Geräte < finite elemente
Die CERA-Technologie basiert auf Direktkopplung zur effektiven Ableitung klangschädigender Resonanzen. ▷ Informieren Sie sich über die CERA-Technologie und machen Sie mehr aus Ihrer Musik mit finite elemente.www.finite-elemente.eu
End of the line product , easy to slide / move the speakers even for a single person
Spikes are horrible for moving / sliding the speakers
I have M 8 inserts under the speakers and i screw them drectly under the speakers .
They come with a box with M6 / M8 and wood screws ( i suppose they supply british and american threads in UK/ USA )
I have 4 footers per speakers but since the footers are height adjustable it works perfect
If you zoom in you can see the principle , the rubber insert on top can be removed .
Unfortunately max weight for Titan Cronos is 280 Kg.ISO-Acoustics makes the Titan Cronus Series that should work well with your speakers.
ozzy
Center Stage. LS 1.5 . No weight intolerance. My speaker weighs over 700 lbs per channelHello there,
Can someone recommend any footers or spike bases for heavy speakers around 350 kg ? Most products i see in the market seem to have a limitation below 300kg.
Thanks
How do you like them? What do you feel they do under the speakers?I have these brand. Both under speakers auva, and under components, EQAuva Isolator - Stack Audio
AUVA SPEAKER ISOLATORSBring your music to life The Stack Audio AUVAs bring your music to life. The AUVAs are designed to do two things: hold loudspeakers rigidly whilst simultaneously absorbing vibration. They combine the best qualities of both spikes and isolators – without the drawbacks of...stackaudio.co.uk
Hi, Both the Auva for speakers and EQ have the same positive effect on the music. They not only makes music more detailed and musical but they also tighten up what you hear. I really like them.How do you like them? What do you feel they do under the speaker?
Thank you,Hi, Both the Auva for speakers and EQ have the same positive effect on the music. They not only makes music more detailed and musical but they also tighten up what you hear. I really like them.
Actually, I just found that out- machined AluminumThank you,
What material the the AUVA body is made of? Metal, plastic?
