Footers for heavy speakers
an.vamv
29
20
298
Hello there,
Can someone recommend any footers or spike bases for heavy speakers around 350 kg ? Most products i see in the market seem to have a limitation below 300kg.
Thanks
Reactions: PhP
andromedaaudio
8,496
2,844
1,400
Amsterdam holland
Finite Element Classic footers.
End of the line product , easy to slide / move the speakers even for a single person
Spikes are horrible for moving / sliding the speakers
an.vamv
29
20
298
Thanks for the suggestion. Can these be screwed directly onto the speakers and if yes with what bolt size?
andromedaaudio
8,496
2,844
1,400
Amsterdam holland
I have M 8 inserts under the speakers and i screw them drectly under the speakers .
They come with a box with M6 / M8 and wood screws ( i suppose they supply british and american threads in UK/ USA )
I have 4 footers per speakers but since the footers are height adjustable it works perfect
If you zoom in you can see the principle , the rubber insert on top can be removed .
Reactions: an.vamv
an.vamv
29
20
298
What's the weight of your speakers and what changes in sound did your notice after the introduction of the Cerabase classic?
andromedaaudio
8,496
2,844
1,400
Amsterdam holland
Around 250 kg. P / speaker.
I have never tried another footer under this model.
10 years i have experimented with all kinds of footers.
These speakers themselves are completely inert , so there is hardly a problem to solve
Golum
1,814
2,577
405
Lausanne, CH
sbnx
1,208
1,361
290
Track audio solid spike feet.
Hello there,
Thanks
Center Stage. LS 1.5 . No weight intolerance. My speaker weighs over 700 lbs per channel
Reactions: Mr Rickz
Magnuska
91
76
85
57
I have these brand. Both under speakers auva, and under components, EQ
ozzzy
300
152
135
71
Here is what I have under my 220 lb. speakers.
ISO Acoustics Titan.
ozzy
Maril555
388
346
370
Any experience with Nordost Sort Fut under the speakers?
Maril555
388
346
370
How do you like them? What do you feel they do under the speakers?
Magnuska
91
76
85
57
How do you like them? What do you feel they do under the speaker?
Hi, Both the Auva for speakers and EQ have the same positive effect on the music. They not only makes music more detailed and musical but they also tighten up what you hear. I really like them.
Maril555
388
346
370
Thank you,
What material the the AUVA body is made of? Metal, plastic?
Reactions: Magnuska
Maril555
388
346
370
Thank you,
Actually, I just found that out- machined Aluminum
Reactions: Magnuska
