To whet your appetite:Hello nirodha,
No, it is related to the German distributor, I just put it as an example of small space and vertical Spacehorns. I hope I will get AG G3 in the future, either a duo mezzo or trios.
The point is that, like Roy, he also used both input and the output of daisy-chain BNC sockets (on passive xover part), for signal grounding with QKore unit.To whet your appetite:
I use the Nordost Qkore for the iTron on the Trio and I use a CAD GC1 on the Spacehorn. Individually each box works great on its speaker. However, don't connect these two together on the same ground box. The result was not good.The point is that, like Roy, he also used both input and the output of daisy-chain BNC sockets (on passive xover part), for signal grounding with QKore unit.
And the dedicated ground lug on the iTron module is apparently for the chassis grounding, which I guess Todd used CAD grounding in this part but as shown in this video, the QKore unit is also used on iTron module for chassis grounding.
Hello everyone. I decided to post a video about integrating a subwoofer with the Trios. It is in my typical rambling fashion. i know there is stuff I left out but I think it is enough to get the gist of what is going on. I edited down the measurements to just the minimum to communicate the path to find a suitable location. If anyone has any specific questions about one of the measurements or how to interpret them or any of that stuff just ask.
Funny you should ask...I wonder if you mean J.R. Boisclair of Wally Analogue? I literally just pinged a post on another thread to Doctorwhy who owns XLFs and in his signature block has listed a "custom 4-speaker bass array by J.R. Boisclair of Wally Analogue". And I asked him about those since I am also looking to massively upgrade the Velodyne DD18+.Anyone know who this J.B. E'claire guy is, who helped the both guys in the review with the bass? (obviously I'm butchering the name - apol0gies!)
Hi LL,Funny you should ask...I wonder if you mean J.R. Boisclair of Wally Analogue? I literally just pinged a post on another thread to Doctorwhy who owns XLFs and in his signature block has listed a "custom 4-speaker bass array by J.R. Boisclair of Wally Analogue". And I asked him about those since I am also looking to massively upgrade the Velodyne DD18+.
Wilson Audio XLF
I'm really curious about the tweak noted here. The use of stillpoints/HRS and 45lbs of damping...really? Can you tell me more about your perception of the magnitude of change in the dynamics. It appears from the photo that you have placed this weight right on top of the "can" behind the resistor...whatsbestforum.com
What an absolutely amazing journey, Todd! Thank you so much for taking us with you, step-by-step on this journey!I set out well over a year ago to establish a really quiet system that was capable of great tone, expressing minute levels of dynamic shading and would possess precise timing queues. Well, the Avantgarde Trio system has finally come together. For the first time in a year I am listening to two speakers. During that year I worked to understand the general location of the main trio + Spacehorns, the general location of the Torus subs and “roughly” integrating the left speaker. I had the left speaker to a point where I could easily evaluate changes to the system. I evaluated different grounding boxes and ground cables, different interconnects, different DAC, power cables, vibration control devices and the list goes on. I feel that I have achieved my goal.
This is the most musically expressive system I have ever experienced. It doesn’t have any of the typical negative horn traits. It sounds like a “normal”, coherent speaker with dynamics (both macro and micro) that are off the scale. This system has an insane amount of resolution. There is no brightness or glare. In fact, this system can be dangerous. I can listen to extremely high SPL’s without realizing it. The sound is so clean and pure that I simply don’t realize how loud it is.
I have one pair of the dual spacehorns. The spacehorn is perfectly integrated with the main trios. The volume on the spacehorns is currently set at -11.5 (-12 is the lowest it can go) yet the bass has extreme power. The bass is also very clean and articulate. I really don’t know how else to describe it. It has to be experienced to comprehend how this feels. The spacehorn is quite the cameleon. It is able to change and adapt to the type of music. It is truly mind boggling as to the range of sounds the spacehorns are capable of. They can be very light and airy sounding on the intro to Rossini’s L’Italiana in Algeri. They can produce chest pounding craziness on EDM. They can be round and thunderous on orchestral drums. They can sound plump on upright bass.
I always heard and heard people talk about horns lack of imaging. This is simply not true with the trios. With the trios properly dialed in I have extremely precise, perfectly sized images that are spread across a wide, tall and deep soundstage. All of the members of the orchestra are properly placed and none of the musicians are wandering around during the symphony. It is very easy to hear where the first violins are sitting compared to the second violins. Very easy to place all of the members of the orchestra -- the clarinet, oboe, bassoon, cello, double bass, horns, percussion, etc. all have their place and are very solid. As far as depth this is not a problem at all. In fact there is one peace of music I listen to that has a flock of birds chirping and swirling around. These birds are well behind and outside the left speaker. No issues at all with imaging and soundstage.
The sound is very melodic, whether listening to an oboe solo, piano solo, female vocals, jazz trio, EDM. It doesn’t matter. Everything sounds like music. I think in most “books” Avantgarde horns with CH Precision and Nordost cables would be a very unlikely combination of components to produce a rich, melodic sound. But there it is right in front of me. The artistic intent is obvious. One of the concerns I initially had was “Can an extremely resolving system still produce music?”. The answer is a resounding YES!
I discussed the subwoofer placement in one of the videos. I did add a pair of WB Torus subs to supplement the trio system below 35 Hz. I found the best general area with REW and then integrated that for time alignment. What this brought to the party is what all well integrated subs bring – an even bigger sense of space and subterranean substance. A pair of PureLow would be even better!
I left my wife alone to listen to the system. She stayed in there for quite a while listening to all kinds of stuff. She normally doesn’t listen very loudly. But as time went on it was easier and easier for me to hear the music in the kitchen. The volume just kept climbing. She said she really enjoyed the soundtrack to Wicked. Here are the adjectives she used to describe the sound: melodic, quiet, crisp, clear, syncopated, precise, beautiful.
To get to this point I booked time on Stirling Trayle’s calendar. The trio is a lot of speaker to wrangle and Stirling has what I think is the best ear in the industry. As he has done speaker setup for a living for many, many years, he can very quickly hear what is wrong and knows what needs to happen to the speaker to remove the malady. We spent over 80 hours together in the past week to fully dial in the system. (I don’t mean 40 hours for him and 40 hours for me. It was over 80 hours of work). It was an awesome, fun experience that I learned a lot from. The Trio is extremely sensitive and revealing of even the smallest of movements. Many of you who have followed this thread know that I use a digital level that is accurate to 0.001 degrees. At one point we were adjusting the azimuth of the left speaker. Stirling would go over to the speaker and make a very small turn of the spike. The effect was immediately audible. We made 5 such turns and it took four turns before the level moved 0.001 degrees. Amazing. By then end we were both totally exhausted. However, the result was totally worth the effort. I can not thank @stirlingtrayle enough for running this marathon with me.
I know a lot of you really love videos. I will post a few with various types of music clips.
As is this. Seems you missed the purpose of his prior post.If the sound on those videos is the sound that you are after then it shouldn’t be too hard for you to achieve that with your system. Pretty low bar Al.
There's no need for multiple tables just to adjust VTA. Many tonearms have adjustable VTA, which can be adjusted / set based on LP thickness.I assume this is a question for me. If not, please forgive.
I do have R2R. It is in the DAC.
Seriously though. A TT is a whole different journey. I think I am too neurotic to have a TT. I would be constantly stressing if the VTA was good enough or having to adjust for each album thickness etc. Of course, I could be like Mike and have a different TT for each album thickness and that would solve the whole problem. Maybe someday. I have thought about the Grand Prix Audio Monaco. But then there is which tone arm/cartridge etc. Then there is the phono stage. For now, I am quite happy with my digital which is not even at the top of what it could be.
I think it really depends on your experiences. Many older horns from the 70s, 80s, 90s to my ears sounded like Scott said; my experiences were - want concert - like volume but want your ears to bleed, get horns, otherwise get planars or cones. About 10 years back, I heard the JBL Everest and they were abysmal. Tinny, non - coherent however, I do recall the gear not being anything special, FWIW.This is slang for I did not investigate horns much but am ashamed to admit that so making up an excuse that people who have not investigated horns will relate to.
What next, digital people who convert to analogue saying before I found this TT cartridge, and phono, vinyl always sounded colored and inaccurate
