ARTsa and LP125sa -- CJ goes stereo
Mar 24, 2012
35
Maryland
parttimeaudiophile.com
I heard that the LP125M amps (monos) are no longer being made, instead, the company has introduced the stereo version, the new LP125sa. With the new ARTsa, it seems that Conrad-Johnson are moving to stereo over mono blocks generally.
Has anyone heard either amp?
Anyone had a chance to hear the comparison to the mono version?
All it really means is cj have one chassis that has 8 x 6550 or kt120's. That config can be either in stereo or two chassis mono block. Gives quite a bit more flexibility IMO.
I thought in the mono version, it was 8 tubes in each mono...so 16 tubes total?
I remember speaking with a few engineers about taking my CJ stereo amp (since sold) and getting a second one to go mono. They said the main differences would be greater solidity in the bass line, better separation (obviously...no cross talk with monos), a broader soundstage, and finally potenially greater ease/effortlessness of delivery (thought that would depend more on the load of speaker the amp(s) were driving).
I cannot say if this would apply here...particulary as i dont know your speaker. But that was what i heard from the engineers (one from BBC who retired and went into audio, and the other from CJ).
Correct Lloyd.
8 tubes per chassis. Stereo could be upgraded to mono and go from 125/140. up to 250/275 watts.
Correct Lloyd.
Hey Turntable - i know you had the Gryphon Colosseum in your system for a while...how would you compare the Colosseum to the big CJ tubed monos? I am just curious particularly as your system and mine are now (once again) extremely close...both GATs, both TA Ref cabling (i now have XLMM2), analog/analog-like front ends, and big Wilson speakers.
i've never had the opportunity to have big cj monos in my system...so just wondering. no desire to switch, but certainly always curious! thanks!
Hi Lloyd
Its all too long ago to accurately compare. All I know at the time the extra $$ was too much. Btw, Nordost Tyr speaker cables now.
Cheers
Hi Lloyd
Cheers
Thanks...congrats on the Nordost!
