TRHH Active Member Nov 14, 2022 109 54 35 61 Aug 14, 2023 #1 If you are using an Cisco Meraki Go Switch and what to test Finisar FTLF1318P3BTL than this information is for you: 2 X Finisar FTLF1318P3BTL arrived today - Until now it works fine with my Cisco Meraki Go 8 Port Switch (GS110-8-HW-EU). Just plug and play. Torben Reactions: harsheel_dbs
harsheel_dbs Well-Known Member Mar 12, 2020 60 36 85 40 Aug 17, 2023 #2 out of curiosity, which cable did you use with them...and how do they sound compared to what you had before?
TRHH Active Member Nov 14, 2022 109 54 35 61 Aug 17, 2023 #3 I use the best you can get (Grade B): Torben Reactions: harsheel_dbs
harsheel_dbs Well-Known Member Mar 12, 2020 60 36 85 40 Oct 6, 2023 #4 this combination has been recommended to me by my switch manufacturer; I am looking forward to trying it out as well! Reactions: TRHH
TRHH Active Member Nov 14, 2022 109 54 35 61 Oct 26, 2023 #5 Final setup Torben Reactions: harsheel_dbs
harsheel_dbs Well-Known Member Mar 12, 2020 60 36 85 40 Oct 27, 2023 #6 excellent! I am enjoying my Finisar modules as well; just awaiting one more ethernet cable and then will try different wiring configurations between wall, switch, fmc and server/streamer.
