Is 180g Vinyl Worth It?
Al M.
10,491
6,264
2,493
Greater Boston
Only if better music and recording/mastering quality justify the expenditure - not always a given with heavier vinyl. This quote from the article rather sums up my own feelings:
"Perhaps in the early days, a little more care was taken over the production of 180g vinyl; however, in modern times, there is also an element of marketing and re-pressing with releases on 180g to increase sales.”
Simon Webster, sales and marketing co-ordinator, Rega"
What do you think Al M.?
No
Reactions: amrs
Few advantages in a 180gram record, especially since it is better and easier to clamp a normal record to be flat.. 180 are harder to clamp correctly
very little relevance of vinyl thickness and sound. and zero proof one way or the other.
sure; there are more original pressings with great sound with thinner vinyl; but that proves nothing. do they sound better since they are thin? do they sound better since the vinyl formulations are different? do they sound better because they have the advantages of being originals? we know lots of early 50's vinyl is quite thick. and the better DG early vinyl is quite thick. over the years there are plenty of each.
i do think 180 gram pressings have a bad reputation due to all the fair to good reissues done with them. and fewer gems. some 180 gram dogs for sure. but there are also certainly plenty of gems. my Classic Records LZ Box set is 200 gram and probably the best sounding records i own overall. but certainly not because they are thick. i have likely 1500 45rpm pressings, most of which sound amazing and are mostly 200 gram.
and for those here who are serial VTA/arm height adjusters; just because sometimes thick records could sound better with a VTA adjustment, does not mean they don't sound fabulous without that adjustment. and if you are always messing with your VTA that is not doing your arm any mechanical solidity favors. pick your poison.
life it too short to just not play thicker records. a silly notion.
i think this issue is completely anecdotal evidence and subjective opinions. YMMV.
If I had a third tone arm, I would simply take one of my duplicate cartridges and set it up for thicker vinyl.
I do find that my 180 g records have slightly less nuance and ambience. I don’t know if that is because the thicker vinyl is more damped and then the mastering process compensates for that by enhancing particular frequencies, but that is certainly a possibility.
To answer the question, I don’t think 180 g records are worth it if an original or thinner vinyl repress is available. But if it’s the only one you can get, and you really like the music, I guess it’s worth it because there’s no alternative.
Reactions: Al M.
Considering that most modern 180g vinyl is cut from digital masters, probably the heavier vinyl will damp the steps due to bits a little better ... ;)
I’d be surprised if someone didn’t chime in to “wake us up” with the classic “your new vinyl is cut from digital” reminder. Thank you.
Well, in fact you seem to prefer to live in a dreamlike world and love to post with out even reading the original post with care.
The referred article showed the picture of a new 180g release from digital masters, available in my local record shops at around 20 euros. It was was what triggered my post.
I missed this chapter in Floyd Tool’s reference book. I’m glad the professor mentioned it in his lecture.
Peter,
Why trying to fight with personnel easy and tasteless remarks?
But I would like to know your personnel opinion of the Floyd Toole book.
Perhaps one reason it doesn’t sound as natural.
Nonsense. This thread is embarrassing. If you are playing 180 gm LPs with the same cartridge parameters you use for 120gm LPs, you are ignoring the simple physics that mandate a change in the SRA required when playing thicker vinyl if you want to obtain the best sonic results. It gets worse as arm height adjustments (for VTA/SRA) are just the beginning of the mandatory adjustments . When you change the arm height you typically have to change VTF as well (typically 0.05-0.1 gm). If you use a pivoted arm, other set-up parameters will not only be inaccurate as well (i.e azimuth, zenith?), but may cause JR Bosclair to have a stroke if you do not account for their changed requirements.
This is a topic that has been covered previously in great detail. To begin, the RIAA standard for 33 1/3 rpm LPs are listed here
What is well known is that unfortunately there is no "standard" thickness for an LP of a given weight. In general, the range of avg thickness for 120gm LPs is 1.2-1.9 mm and for 180 gm LPs it is 1.5-2.8mm. Some of this depends where you measure as the thickness is not necessarily uniform across the surface of an LP a shown here:
However, the point of several posts on this topic suggest that some folks believe that the parameters used for playback should be the same for LPs of different thickness. Or, put more accurately, that there is no difference sonically when different thickness LPs are played on the same rig. I strongly disagree. Here are some comments that I think are still relevant from previous post in 2023.
https://www.whatsbestforum.com/threads/using-wally-tools.37229/page-7#post-912061. #123
The bottom line is that 180 gm LP are generally about 0.012" (~300 microns) thicker than 120-140 gm LPs. If you have set up your LP rig with a "standard" thickness LP (generally 120gm or 140 gm LPs) and are playing180gm LPs with the same arm height, it is almost certainly not performing optimally if you do not change some important parameters; most notably arm height as mentioned above. The difference in cartridge/arm optimization between 180gm LPs and thinner LPs is so easily demonstrated that every single visitor who has heard me demonstrate this in a controlled and blinded experiment has unequivocally agreed. It's really quite easily heard. The take away summary is that for this and many more reasons, LP playback is a huge pain in the ass that is made even more onerous if you want to play LPs of different thicknesses on a rig that you optimized for playing LPs of only one thicknesses. Deal with it. Here are 4 ways to do so.
1) Adjust your arm height (and other requisite changed parameters) for optimal playback for each thickness of LP in your collection. Get a discounted rate to a psychiatric facility at the same time. You will need it.
2) Take an "ignorance is bliss" approach and don't change anything once you've optimized your system using a reference LP or LPs to set up your rig. Let's face it, the sonic changes of minute adjustments mandated by adjustments for different LP thicknesses are not earth shattering and may not be critical for many or even most listeners. In this case, an "if it ain't broke, don't fix it" mantra might just be right for you.
3) Set up your turntable for a 120 gm LP and use a 500uM thick Herbie's mat for 180 gm LPs. (Not ideal but can be very beneficial)
4) If you have a TT that allows 2 or more arms, use 2 identical arm/cartridges with one set up for 120/140gm LPs and the other for 180/200 gm LPs. This method has a lot of merit and frankly, I'm surprised its not utilized more frequently, especially by folks who consider themselves "critical" listeners.
Reactions: microstrip
