Xhadow XLR Connectors Any Substitutes?
ozzzy
347
178
155
72
Xhadow XLR connectors.
In my opinion, these are one of, if not the Best XLR connectors ever made. But I believe they are no longer made. So, I am looking for a replacement.
Other than sound quality, what I also liked about the Xhadow connectors was they have set screws for making the connection rather than having to solder.
Anyway, any other XLR connectors that I should consider that is similar to the Xhadow?
Here is some more information.
"The Xhadow Precision XLR is easily the finest XLR in the world, designed with respect for the audiophile perspective: Precision, purity, simplicity and elegance.
The main barrel and rear-nut are lathed from pure aluminum rod-stock and anodized in "Xhadow Gray" for a durable and non-conductive finish. This assembly houses an internal strain relief that is machined from brass.
Into this barrel assembly fits our Gender-Modules - either male or female plugs. Each one has an outer passive shell machined from brass and mirror plated, a machined Teflon dielectric, and pure copper machined contacts that have been silver-plated. Each contact allows the termination of wire to be completed via solder, set-screw, or both. This gives the end-user a tremendous amount of flexibility while also allowing them to guarantee a fantastic contact interface with their wires. Each Gender-Module is engraved with the "XHADOW" name along the top arc of the shell's front border, indicating top-orientation.
The fit of these connectors is smooth but very strong, with a tremendous amount of contact pressure to ensure perfect and consistent signal passage with a minimum of contact resistance."
ozzy
miniguy,
Thank you for that recommendation. Still requires soldering though.
ozzy
ozzy
Neotech make high quality UP-OCC cryo XLRs, choice of gold or rhodium plated. I had a pair of NeoTech NEMOI-1220 OCC rectangular silver cables made with the gold plated ones. Here the wholesaler (HiFi Collective make the cables up, do a super professional job. They will ship anywhere. Charge about $40 per cable. Most of the time is preparing the cable.
The still seem to be selling Xhadow, and also sell the Oyaide.
Reactions: SCAudiophile
HiFi Collective has a huge resource for making up all sorts of cable and connectors.
I don't have a problem soldering, but I prefer not to. Especially if I want to experiment with different wires. The Xhadow had screw terminals. I will check with hifi collective if they still have them available. I live in the USA.
ozzy
ozzy
For set screw connection, another option is this top Furutech XLR and its male mate.
Reactions: flowcharts
Miniguy,
Thanks, I'll see if I can find the Furutech.
ozzy
Reactions: Sablon Audio
I am surprised at the cost. What makes them so expensive?
ozzy
Bocchino BAXLR (R9) hands-down one of the best out there IMHO.
+1
I have tried too many XLR connectors to name, with nearly every type of metal (except rhodium, which I deplore). Carmine's connectors are the cream of the crop IMHO for several reasons. The quality of the build, the metal plating thickness (Carmine believes the plating should be at least 9 uM thick) and the fact that it is assembled using screws, not solder, all contribute to my assessment. I've tried his pure copper XLR connectors as well as copper with silver, platinum and palladium platings and prefer the palladium by far. But realize this may be preferred because of the cable I use (Masterbuilt Ultra which uses a metal conductor that is not published or specified as far as I know) but the sound of this combo is nevertheless wonderful.
FWIW, I asked WBT if they would consider making XLR connectors with various plating when I visited them at the Munch show last year. Sadly, they said they would not as its too small a market for their business interests.
I'm surprised Xhadow is no longer available as I think they were the connectors used by Bruce Brisson at MIT for many years. I think Parts Connection bought the remnants of Vampire Wire who made the Xhadow connectors so you might try that source?
ozzy
@ozzzy
As I understood what has been explained to me...
Smaller production runs and fastidious levels of detail, hand polished, etc. The bigger manufactures have economy of scale that helps price.
Larger pin sizes, thread-mating, etc. overall larger conductor body (*see important point below) and overall contact surfaces.
High-quality metallurgy, thicker high-end platings, no rare earth blends or plating that influence sonics (negatively).
Connector bodies optimized for sonic neutrality, mating, etc.
Solder-less connections, options for choosing eccentric or regular pins, etc.
*The ability to accept multiple large gauge/cross-sectional area conductors into all Bocchino connectors. The unspoken
truth behind a lot of commodity as well as nearly all high-end connectors is the restricted number and gauge of wires that
can be effectively inserted into and properly terminated in the connectors. For signal, speaker and power connectors this
makes for the need to downsize or limit conductor count and size when looking at the main cable versus what is terminated
within a given connector.
Shunyata and other manufacturers have confronted this too and have designed their own bespoke connectors with whatever
that manufacturer has found is the optimum configuration into the connector termination.
All that stated Ozzy, yes, the cost is not negligible; the sonic results in using these even when compared against some other
top-flight alternatives was enough to win me over and whenever possible, the Bocchino XLR, RCA and speaker spade and
banana connectors are what I've chosen for many years.
I've also found Shunyata's more recent connectors (last few years) are also exceptional on their cables. They do not sell them
to the open market as far as I"ve ever seen.
Thanks.
It would seem to me that the less metal the better the conduction.
Perhaps something like a 3-pin screw insert that you could install the wires into that could be pushed into the XLR on the component.
Where's Elon?...
ozzy
