Roy Gregory Names Clarisys Atrium/VAC System Best in Show
19,638
17,612
3,530
Roy Gregory of Gy8 names Clarisys Audio Atrium/VAC/Kronos System Best in Munich High-End 2025!
My understanding is that no one can buy advertising space on GY8. I think Roy is in a position to call it like he truly hears it.
Agree with Roy on that. I rate WE/Silbatone very highly this year also. Best two systems for me.
No surprise here. The Clarisys Atrium room at FLAX 2025 was among the best of show imo. System included fewer VAC amps, Pink Faun Dual Ultra/MSB Cascade providing the digital source & VPI (iirc) for the analog. An extraordinary performer at FLAX.
It is rather strange that while Roy Gregory mentions the Gobel/Riviera Audio Laboratories room as one of the best sounding rooms of the Munich highend show 2025, he did not specify that Tripoint Audio participated in that set up with three ‘grounding’ stations and 10 Emperor signal filters (four of the latter on the Riviera preamp and one on each Riviera monobloc!). Why did he not mention Tripoint Audio at all?
Because nobody mentioned them to me. Comprehensive system lists get to read a bit like laundry lists so I don't always mention every last nut and bolt. Having said that, I know how powerful the TriPoint pieces are: 13 in one system is always going to make a serious contribution and certainly helps explain the sheer clarity of what was one of the most lucid sounds on show.
Reactions: Rhapsody
Agree with Roy on the Clarisys system - stunning clarity but still great emotional engagement, and for huge speakers, they didn't blow everything completely out of proportion.
Disagree on the smaller Gobels though - sounded as if they were trying too hard, and this from someone who loves the Riviera signature sound.
Andrew Quint of TAS also selects Clarisys Atrium as Best of Show!
I listen very well this room,from one side sound was impressive even of i think VAC is no good match with this speaker because bass was not well refined and medium little veiled with sone track
I think with transistor can be much better
On 101dB sensitive speakers I would never use a solid-state amplifier.
Reactions: fxe02
Those small and hot Class-A amps would be on my RADAR for a 102 dB speaker.
My tip audio agile 24 watt verve or valvet e2se 12 watt at 8ohm65681d.jpgValvet-Open.jpg
For diy people
On 102dB sensitive speakers I would never use a solid-state amplifier.
102dB on horns i would never indeed use SS amps (but I will once I get the specially designed SS amp for horns)
102dB on horns
What does this mean, while Clarisys were playing orchestra the French horn section went up to 102db
