Problems with believability in audio
morricab
11,083
6,427
1,958
Switzerland
There is a new think piece in "The Absolute Sound" that discusses what the author views as the 6 major problems in getting what he refers to as "believable" audio.
This reminds somewhat of the old TAS where Harry Pearson would muse upon what made audio sound more realistic. What this article does is lays out the issues, what it doesn't do is attempt to address them with solutions.
This allows us members of WBF to debate these topics without any preconception from the author...other than we may not agree that all of these points are problems with believability in audio or that some that are important are missing.
The author starts with a statement about what audio is for, listing three points: 1) Enjoyment of music, 2) A quest for a system that makes believable music and 3) Appreciation of Progress
Of these three stated objectives for audio, I resonate strongly with the first two, meaning the enjoyment of music and a quest for a believable system are definitely reasons I am in the hobby. The third point to me is interesting but increasingly as I have personally journeyed in audio I find that there is not so much actual progress towards believability in reproduction (perhaps even some regressions in that regard) as there has been in a purely technical grounds. Yes, we have more advanced electronics, materials, circuits speaker designs etc. ...but how do they relate to the goal of audio believability? I was once believing that more advanced circuits, parts, materials and designs...all driven to reduce measurable distortions of various types, would lead to the greatest believability in audio reproduction.
The problem, as the author points out, is that this hasn't really been the case. I would argue that in some really key areas (some of his 6 problems below) audio had actually regressed compared to the best historical systems.
One interesting point made by the author is that without a reference the pursuit of the points above basically have no direction and what I see is people pursuing enjoyment and a quest without a reference. What ends up happening then is the endless pursuit of different and endless gear swapping.
The 6 points are as follows:
1) The problem of visual images
2) The problem of recording standards
3) The problem of spatial imaging
4) The problem of bass in real rooms
5) The problem of dynamics
6) The problem of digital distortions
He states that the first two are basically out of our control although I guess you could beam videos of concerts in your living room to kind of address point 1. Point 2, you just have to be selective of good recordings, which is generally reached by a consensus of aficionados. It is clear that poor and even decent recordings do quite a bit of damage to believability.
Problem 3, the problem of spatial imaging to me is probably more problematic than most would like to admit. Without knowing what the real event sounded like (or if in fact there was a real soundstage and not just manufactured in the studio) I think it is less critical that it is accurate than if it just seems palpable and believable (like the sax player or vibe player is there in the room with you in 3d ). Where most systems struggle here is in terms of image density and 3 dimensionality. Do they have volume like real musicians in a room would have? Most systems paint a rather flat caricature of this, even if they place them well in a deep/wide soundstage. After just coming back from Munich, most systems, regardless of cost, fail to convince that the images are living, breathing musicians.
Problem 4, the problem of bass in a real rooms is maybe less of a barrier to believable sound because real instruments in that same room (at least bass instruments) SHOULD have similar problems if they are located approximately where the speakers would be located in that room. Of course you can't fit large ensembles in a small room nor would you want a rock band in your room, which would like sound pretty bad.
Problem 5, The problem of dynamics is also what I consider to be one of the biggest problems with believability. Most systems are woefully underrepresenting dynamics and it is one of major reasons for the renaissance of horn speakers...which were virtually dead 30 years ago. You can hear most non-horn speakers compressing even if you don't really realize it...mostly because that is just what you are used to. Real dynamics are purely the domain of high sensitivity speakers because of the physics behind thermal and dynamic compression. Speakers of mid-80dB sensitivity are already compressing significantly from moderate volume levels. This then doesn't allow for the natural dynamic envelope to be expressed. Some very large dynamic and panel speakers do this kind of OK (the Sigma MAAT is a good example) because they have somewhat high sensitivity due to large radiating surfaces. Speakers under about 95dB sensitivity will never achieve the same dynamic expression of their more sensitive brethren, IMO.
Problem 6, The problem with digital distortions. This is a difficult one as most people these days are primarily digital. That said, again in Munich it was often with a sense of relief when a room would switch from digital to analog. I know this will draw fire, but the ubiquitous use of WADAX players was for me a digital catastrophe. I remember many years ago going around the Munich show and taking note of the gear in the rooms that sounded good to me. One year I noted that the Audio Aero La source was a common feature in the rooms that sounded good. This player and the La Fountaine were very musical and seemingly pretty low in the kinds of digital distortions that interfere with believability. I noticed a similar analog trend a few years ago, when several rooms had adopted the Kronos Pro turntable....those rooms tended to sound very musical compared to other rooms also running analog. What I have noticed with WADAX is that room after room sounds "synthetic" or as my wife put it "electronic" sounding. There is something missing in the dynamics and a sheen to the sound. I don't care how great they measure (if they in fact measure that great) what I hear from them doesn't sound believable. Ultimately, I have stayed with classic R2R chip based DACs (BB PCM 63 and 1704, AD 1865 etc.) and tube output stages because, although clearly worse measuring, they simply sound more believable to me based on what I hear with live, unamplified music. It doesn't matter if they are SLIGHTLY lower resolution or don't have as much air...they simply sound more real to me...in the way that good analog sounds more real.
What are your thoughts? Would like to have some other's thoughtful feedback...
Sorry i did nt read through the whole piece yet .
The problem is Reviewers dont know to distinguish good sound when they hear it lol
No, I think this misses the point completely...try to read the whole thing before commenting.
Dear Sir,
Spatial correctness and realistic approximations of dynamics are the hardest challenges to audio systems.
The vast majority are no more than expensive failures in these domains, my experience has lead me to converse with fewer and fewer 'philes and purveyors.
Mr. Martin is asking the tough questions with composure and diplomacy, an admirable and under valued set of skills especially amidst the ever increasing throng of ketamine fuelled politico bravura.
Kindest lament, G.
Dear Sir,
Kindest lament, G.
I agree! Thanks for your valuable feedback...I found it fascinating that someone was willing to put out such questions...very refreshing
I would add accurate instrumental tone to that list, but in my opinion, dynamics is the most overlooked aspect of high-end audio. Perhaps we could consider dynamics, along with liveliness and a lifelike character—without being edgy or harsh.
I believe dynamics plays a major role in making a setup engaging.
Agree that tonality is crucial but I am not sure if it is accurate tone or the ability of a system to resolve the tonal variations between instruments, including instruments of the same type (such as different violin makers), that is more important. Perhaps if the system truly has accurate tone the point is moot; however, there is probably no system that nails it 100%.
I agree on dynamics. I agree that horns are the best solution for that particular sonic attribute.
They’ve left off the seventh issue and that is the dependence of the live sound at your ear on where you sit in the hall.
I attend live events every week. My home system gives a consistently superior sound experience if the only criterion is the sound.
No, can't agree with this one. Live sounds live...even if it is crappy live. You can tell if something is live or not even from a long distance away. I was on holiday in south of Spain once and we were in a small costal town near Portugal. They were having some festival and we were shopping down some small alleyway like streets. From a long way off we start to hear music playing and it was immediately clear it was live. About 10 minutes later this small horn and percussion band came right down the street we were on thus confirming the initial assessment. They must have been several hundred meters away or more when we first heard them in the distance but it was unmistakeably live.
I don't doubt that your home system gives better sound in a lot of cases. That is not the same as believability...
Dynamics for me. When I placed a really good PP tube amp on my speakers, the small, inner dynamics absolutely destroyed the Dartzeel. The SS amp homogonized it all. Now, the SS amp has a more robust and rounded weight to the music. But that takes me to the point of digital sounding. I know people with BACCH. While they have s flat frequency response, you are always aware it sounds digital. Its really nice sounding. But digital.
Then it comes.to music. Much music people listen too, who cares if its digital sounding. Bass and even tone is more important. And easier to obtain using dsp to get you there.
Maybe what the author is not addressing is preference.
It sounds like you are arguing that there are many flaws in live sound that distinguish it as more believable.
Sort of like arguing that a picture of a model before photoshopping is more believable than the tweaked version that makes her look even more appealing.
There is an eighth point .. and that is the fact the the person who did the mastering has different ears and hearing receptors compared to the person who is judging during listening.
What do you think is best for the other attributes listed?
For dynamics, bass, and transparency to show recording standards, it’s horns.
Visual imaging is based on believability and if there on the record, comes out through horns. I understand some might try to out here the Magico type visual cue.
I think what the article misses out on is balance and coherence and contrasts
Can you just send both of the pictures - and I’ll decide?
Reactions: Another Johnson
Audiophiles suck up visuals like candy.
Its where its all about .
I havent even included cable pictures
As im morally against taking cable pics in munich lol.
Harry was a music lover and one that attended numerous live concerts. Harry discussed this and made this live unamplified sound his goal. He said this many times. As someone that was around then and went to many concerts with HP and others like Arnie Nudell and Mike Kay this was always what he strived for.
My point here is I do not think that most actually have a goal. I don't recall the author ever describing his goal and the path taken to achieve such. In fact I don't believe that most reviewers ( not all) ever have described what they potential end game goal is for them.
I don't personally ever expect in my lifetime to have live music in my home or room from an audio system. I don't think this is a realistic goal.
I do go to live music reasonably frequently although no where near as often as I used to. I don't like large scale bad venues and not that fond of crowds at this point of my life.
I think all of us need to know what we are trying to achieve and then go after it. I see here and elsewhere many trying to travel to a location but have no idea where it is.
The same Tom Martin who wrote the think piece that is the subject of your post has talked about the Mola Mola Tambaqui DAC in that context:
He points out that the Tambaqui DAC solves some important problems with digital distortion.
In my system it has a tonal balance and tonal density comparable to my previous R2R DAC (Yggdrasil LIM), but it sounds much cleaner and purer, in the highs and elsewhere, and also more natural (believable) and less synthetic than my R2R DAC. That DAC had already stood out as being more natural sounding than quite a bit of other digital, especially on physical CD playback.
The Tambaqui sounds more analog, also due to the lack of digital distortion (which Tom Martin addresses in above video).
Reactions: bonzo75
