SUT Shootout
Agree with above. I've tried over a dozen different SUTs in just the last 2 - 3 yrs and some ok and others GREAT. ANJ-Kondo have been very good but Audio Note UK not anywhere the sound quality of ANJ. One of my favorites was S.A. Labs (out of Russia) had 3 different units my favorite was their K-25. Beautiful sounding. Koetsu was another recent purchase and again just wonderful. Tried a MSL SUT with my MSL Sig Platinum and while good an Airtight worked much better. Actually the Airtight is now a keeper. Has worked well with several different cartridges.
Lots of choices ....good luck in your own quest.
The AirTight ATH-2 Reference is a keeper for me. Love the sound and punch from it ;) !
/ Jk
If one has a low impedance MC cart, maybe consider the Sutherland SUTZ as a step up alternative. It is superlative IME.
Or this more inexpensive product:
Cool. We did trials before the release of the SUTZ. Ron designed a battery version, smaller version, etc. They all worked well, however, the extremely well crafted linear supply and the discoveries from the Dos Locos transimpedance input stage make the SUTZ pretty special and decided the best offering from Ron. It is not to be considered an overpriced transimpedance step up. It is tested, evaluated, carefully chosen parts and layout for best sound.
If you think that one is really good, you should hear the ATH-2 Ref
not correct regarding the ATH-2 models. They use Hashimoto transformers.
@miniguy Just a quick follow up on this. I'm surprised the ATH-2 SUTs use Hashimoto rather than Tamura transformers, as Air Tight seems to use Tam for most everything else. Just wondering if you had any more info on this, and perhaps know which Hashimoto transformers they use. I'm most curious about the ATH-2 Reference and what might be inside that box. Cheers!
ATH-2 Ref uses HM-7. Also notice the ATM-1 amp uses Hashimoto output transformers.
Reactions: wbass
Thanks for that. I believe the HM-7 is Hashimoto's flagship SUT and is well regarded generally. I priced out a SUT using the HM-7 from a maker in Michigan, the Live! MC SUTs, and was quoted around $1700 (in 2020). Air Tight definitely puts their own premium on them, then, but I suppose the ATH-2 Ref gives you three inputs, and presumably the wiring and switches are quality.
As it stands, I picked up one recently secondhand, and it's a really well built box. So much so I'm (idly) contemplating an Air Tight pre/power combo. I look forward to shooting the ATH-2 Ref out with an EM/IA silver, a SilverCore Reference, and a fonoLab SUT built around Tamura transformers.
As it stands, I picked up one recently secondhand, and it's a really well built box. So much so I'm (idly) contemplating an Air Tight pre/power combo. I look forward to shooting the ATH-2 Ref out with a EM/IA silver, a SilverCore Reference, and a fonoLab SUT built around Tamura transformers.
I look forward to your comparison results.
Reactions: wbass
Are you really sure that the ATH-2 uses the Hashimoto HM-7?
If this is confirmed I could make a DIY SUT using the HM-7 at 1/4 of the price charged by Air Tight.
Never heard the HM-7, but the much appraised HM-3 is NO MATCH for the Parmeko oilfilled vintage SUT
DaVa Soul
Does any one have any experience with the Audio Note Japan AN-S4 ?
This is pre-2001 and uncommon, to say the least. Dates to before the AN-UK/Kondo split. "Silvered" windings, selectable impedance matching.
I have been offered one for sale, and wondering if it is worthwhile.
Seems to be a very interesting piece. With both different turn/impedance selections 3ohm/33x?: 10ohm/10x : 20ohm,,,,, 40 ohm. ..? And secondary loading options.
A tweakers delight , I would maybe buy one, but not sure I have the required money
But I recently heard the AudioNote AN 6 Silver UK and compared and volume matched to 2 others expensive SUT, I did rank the AudioNote at the bottom without any doubt. I preferred the Consolidated Audio one
Ask @sjs
If the price is not too high I would say go for it.
I've borrowed an-s4 ii from a friend.
with a Zyx cart, i preferred the ear's 88pb internal SUT over it.
Reactions: Balle Clorin
i would buy it. rare and probably great. i have heard an-uk sut and they were absolutely brilliant, especially the silver ones. then again i bought an audio technica 670t the other day for a couple hundred bucks and it has been fantastic. with the right cart i am sure this kondo sut would be brilliant. and very flexible.
I'm contemplating buying a Consolidated Audio SUT after visiting the Munich show and talking to Mr. Michael Ulbrich, the owner/designer. My question is has anyone used one of these SUTs with an MSL cartridge? If so, your thoughts and which turns ratio did you go with?
what about using the t1030 made by MSL? cheaper than consolidated audio and made especially for their low impedance high output carts. herb on stereophile wrote about the combo of the ultra eminent MSL cart with the t1030 and said he'd never heard better. if i were you i would recreate that. it is on my agenda thats for sure.
