It’s not A2…Class A2 ist a diffrent pair of shoes.. If you work with grid current, there's even more. A little insider tip.
I always drive my tubes so that they feel good and chill, but everyone as they like
I don’t think mains voltage is the issue — I believe the tubes are. All Russian tube designs are problematic. Maybe it’s a matter of manufacturing quality, but we can’t know for sure since they’re not made anywhere else. Lamm, BAT, Tenor, etc.Lamm also quotes a 10% mains operation variation. The problem only happened when after adjusting the bias there was a rise in the mains voltage.
The question is mains stability, not the nominal value.
Sorry, no its is a series regulator pass tube used in regulated power supplies. But yes, its use in MIG fighters is legendary.the 6C33 is a rectifier tube for MIG fighters
only one I know,who uses it as such, is Tommy Hørning in his SATI turntable powersupply
With Lamm, main voltage is almost always a problem. 6cc33 runs at 175v dc at 310mA, 56watt anode power dissipation (60watt max).therefore the regulation.I don’t think mains voltage is the issue — I believe the tubes are. All Russian tube designs are problematic. Maybe it’s a matter of manufacturing quality, but we can’t know for sure since they’re not made anywhere else. Lamm, BAT, Tenor, etc.
I have had good luck with 6C33c tubes, 6N6p, 6N30p, 6N23p etc. Only GM70 doesn’t seem to last that long but my amp drove them at the upper limit to get max power.I don’t think mains voltage is the issue — I believe the tubes are. All Russian tube designs are problematic. Maybe it’s a matter of manufacturing quality, but we can’t know for sure since they’re not made anywhere else. Lamm, BAT, Tenor, etc.
Lamm Ml2 uses one to regulate the output tube…another 6c33c! Unique among SETs AFAIK…the 6C33 is NOT a rectifier tube for MIG fighters, but REGULATOR…….
I have had pretty good luck then because I have owned four different amps with this tube and only once had a tube failure.With Lamm, main voltage is almost always a problem. 6cc33 runs at 175v dc at 310mA, 56watt anode power dissipation (60watt max).therefore the regulation.
In any case, the 6C33 is not a very good tube. Even if you pre-age (bake) it, there is a lot of waste in tubes to achieve the same quiescent current. This is still possible with older ones from the 60s, but with new productions it is a disaster.
Exsample 6c33 (1965)View attachment 154922
Lamm ML2.2 monoblock power amplifier Measurements | Stereophile.com
Sidebar 3: Measurements To measure one of the Lamm ML2.2 amplifiers (serial no.B10254), I used Stereophile's loan sample of the top-of-the-line Audio Precision SYS2722 system (see www.ap.com and the January 2008 "As We See It").www.stereophile.com
Lamm ML2.1 monoblock power amplifier Measurements | Stereophile.com
Sidebar 3: Measurements Following Vladimir Lamm's instructions, I let the ML2.1 run for an hour or so before I checked the output tube's plate voltage and current. While the voltage was correct at 175V DC, the current was a little high at 0.35A. I adjusted it to read exactly 310mA, as...www.stereophile.com
The output transformers look pretty adequate on these two later versions of the ML2. Note from the 8 ohm tap into 2 ohms it’s still not saturating. This is not high power but shows a good transformer design.
BAT, on the other hand, has quite obvious core saturation even though the amp is a circlotron PP design.Balanced Audio Technology VK-56SE power amplifier Measurements | Stereophile.com
Sidebar 3: Measurements I measured the Balanced Audio Technology VK-56SE using my Audio Precision SYS2722 system (see the January 2008 "As We See It"). The VK56-SE looks identical to the VK-55SE, which Wes Phillips reviewed in April 2010, and it was instructive to compare its measured...www.stereophile.com
Toroids don't make good output transformers as they saturate much more easily than EI core designs. If the tubes had been properly (dynamically) matched its a good bet the saturation problem (if that is really what is being shown) would not have shown up.BAT, on the other hand, has quite obvious core saturation even though the amp is a circlotron PP design.Balanced Audio Technology VK-56SE power amplifier Measurements | Stereophile.com
(...)BAT, on the other hand, has quite obvious core saturation even though the amp is a circlotron PP design.Balanced Audio Technology VK-56SE power amplifier Measurements | Stereophile.com
Nice clean wiring. Did you do this?Exactly, Ralph, the socket is the Achilles' heel. Always use the good old Russian ones made of ceramic. Normal tubes have a temperature of 200-250 degrees Celsius, but this damned beast easily reaches 350 degrees Celsius at the socket after an hour. It's a good thing the soldering points are well insulated from the ceramic, otherwise it would desolder itself.
Every six months, clean the socket pins thoroughly; a deadly coating accumulates there, leading to serious failures. Soak the pins in warm distilled water, then clean them...for a hopefully long life.View attachment 154942
I believe the Lamm ML2 is one of the best sounding SET amps ever made. I chose not to get a pair after struggling with the 63CC in my Lamm ML1.1 push pull. Lamm said that he’d have to throw away 75% of them to get tubes to his SPEC.With Lamm, main voltage is almost always a problem. 6cc33 runs at 175v dc at 310mA, 56watt anode power dissipation (60watt max).therefore the regulation.
I replaced a few components that were no longer working properly, and a few cables because they were humming a bit. You can clean the sockets with interdental brushes and isopranol alcohol.Nice clean wiring. Did you do this?
How do you clean inside pin sockets. I can get in a KT pin socket. Its the small driver and signal tubes that are the issue. I have a thin cotton pipe cleaner for the larger holes.
