I have just about concluded my 2+ years of research, flying around the country, and have assembled and evaluated the best fitness equipment available on the planet. I thought I would share my results. I have been absent from audio and video due to the length and involvement with this dream project and other hobby of mine. But here is the latest version of my results:
I am focusing primarily on machines, benches, attachments, and bars. I think it is best to stay away from racks since there are tons of great rack choices on the market, and people have different priorities when it comes to picking their cost no object rack.
Another thing here is this is not meant to be a Free weights vs machines thread, and I think we got that out of the way early in the thread. This thread is simply about discussing all the choices of various free weights and machine choices on the market that people feel represent the best choice, regardless of cost. Certainly best bang for the buck is always relevant as well, but the thread is primarily focused on what is the best product available.
The short answer is that no company makes all the best equipment, not even close. Additionally, some extreme body types (very short, very tall, very large, etc..) might work better with some equipment rather than others. However, a machine that is voted best of best is often because it is very adjustable and can be used with the widest variety of body types and still have the best biomechanics. Ultimately, when it comes to machines, biomechanics and how a machine feels being used is the most important factor in determining what machine is best. One of the best ways to determine biomechanics, is the ability of a machine to allow perfect form using a maximum amount of weight on the target muscle being isolated. Additionally, the ideal machine will also have adequate starting position (pre-stretch) and a very large range of motion. One example is the Cybex VR3 arm extension (tricep). It is one of the few tricep machines (of that type of machine) that has upper back support. Other similar machines without upper back support do not allow one to use heavier weights due to the need to use abdominal muscles to hold your position. Without the upper back support, you are pushing backward against your abdominal muscles. In my opinion, the Cybex VR3 with heavy stack (and older VR2) provides the best biomechanics on the market for that particular type of tricep extension machine. Cybex absolutely nailed the grip, arm pad, length of the arms, pad angle, seat, and distance between the grips, pre-stretch, and range of motion. In my opinion, it is the best of all available machines of that specific type and gets a 100% for biomechanics for a neutral grip tricep extension machine. There are certainly other types of triceps machines on the market as well, however, at the moment, this piece also represents my favorite tricep machine. Again, this is in regards to comparing machines, not to comparing machines vs. free weight skull crushers, dumbbell work, or cable pushdowns with various attachments, etc. Which bring us the topic of specialty benches. Certainly we have autospot benches and specialty benches (such as designed specifically for just for skull crushers, dumbbell pullovers, etc...) which are all to be discussed.
Ultimately, only a personal opinion can be offered about what someone considers as the best possible choice in a machine. The vast majority of the choices I feel are superior to all other choices in terms of biomechanics. Sometimes there is a type of machine that you have a few good choices (rows and leg presses for example) therefore all of the choices should be listed, and ranked according to personal preference.
Leg presses:
TOP-TIER:
MedX Avenger Leg Press
Atlantis 40 degree Leg press (with modified wide foot plates)
Rogers Athletic Power Squat Pro
Rogers Athletic Pendulum Hip Press
Atlantis Power Squat (modified additional wide foot plate surface)
Nebula Vertical leg press
Runner-ups:
Nebula 35 degree leg press
Nebula 45 degree Leg Press
Atlantis Fitness Pivot Press (with wide footplate mod)(felt to be better than the Cybex)
UCS adjustable 35-45 degree leg press (difficult to demo)
Elite FTS Mondo 45 degree Leg press
Cybex Plate loaded Leg Press
Strive Plate loaded leg press
Atlantis Fitness Pendulum Leg press (similar to the old Paramount leg press)
Leg Curl:
TOP-TIER:
Star Trac makes the best prone leg curl and bested kneeling leg curl on the market bar none:
Star Trac Prone Leg curl A+
Star Trac Kneeling Leg Curl A+
Various standing Leg Curl units: (Icarian, Atlantis, Legend) (The best standing leg curl to be determined, but prefer standing leg curls to seated leg curls)
Runner-ups:
Cybex plate loaded kneeling leg curl A
Leg Extension:
TOP-TIER:
Strive Fitness plate loaded A+
Leg Abductor/Adductor:
TOP-TIER:
Strive Fitness combo abductor/adductor A+
Calf Machines:
TOP-TIER:
Sorinex seated calf A+
Atlantis standing calf A (Lack of rounded calf block keeps this unit from achieving a perfect score)
Nebula seated calf A
Sorinex Donkey calf
Free Motion Epic calf ext A
Shoulder:
TOP-TIER:
Rogers Athletic Pendulum: Shoulder/Incline/Chest machine A+
Hammer Strength Plate loaded Iso lateral A+
Strive selectorized lateral raise A+
Runner -ups:
Hammer Strength Plate loaded Super Incline (or older version called iso lateral military shoulder press) A- However, improved to A with back pad spacer mod behind upper set of back pad screws)
MedX Avenger Shoulder (overhead press) A-
Traps:
TOP-TIER:
Rogers Athletic Pendulum 5 way neck with shrugs.
Elite FTS Pro Rickshaw
Power Lift DEADLIFT / TRAP BAR
Sorinex Diamond Bar
Triceps:
TOP-TIER:
Cybex VR2/VR3 arm extension. Heavy stack option is absolute MUST have on VR3. Older VR2 is also top tier and has heavy stack included. A+
Atlantis D-123 Pulldown with various tricep attachments. A+
Atlantis Dipping station A+
Hammer Strength Plate loaded seated dip
Nebula reverse dip bench
Biceps:
TOP-TIER:
Strive plate loaded bicep A+
Sorinex Adjustable Preacher Curl Bench A+
Hammer Strength plate loaded bicep A
Back:
TOP-TIER:
Rogers Athletic Pendulum Combo Lat Pulldown
MedX Avenger Row
Hammer Strength Iso lateral MID ROW, with modified chest pad.
Atlantis D-123 pulldown, also comes with 310 lb stack (best cable pulldown on the market, hydraulic seat, etc...)
Atlantis D-132 cable High Row (310 lb weight stack is standard on this).
Dual stirrup Hampton cable attachment or similar chain with Black Iron Strength stirrup handle upgrades.
Strive Plate loaded and selectorised Low back extension with seatbelt.
Legend Reverse hyperextension with curved pendulum and tiltable top vs. Legend older model tiltable with straight pendulum
Runner -ups:
Rogers Athletic Pendulum Row
Hammer Strength High Row
Hammer Strength Low Row
Hammer Strength Pulldown
Atlantis plate loaded Pulldown
Chest:
TOP-TIER:
Hammer Strength HORIZONTAL iso lateral chest A+
MedX Avenger Iso lateral vertical chest
Rogers Athletic Pendulum Shoulder/Chest/Incline A+
Rogers Athletic Pendulum Vertical Chest (non-converging design will cause varying opinions on this machine, highly recommend demo before purchase).
Runner -ups:
Hammer Strength Wide chest
Hammer Strength Decline Chest
Abs:
TOP-TIER:
Hammer Strength MTS selectorized Ab Crunch A+
Hammer Strength Plate loaded AB Crunch A+ (I demoed the plate loaded one in Vegas and it was just as good and also allows twisting of the seat for obliques. Also 4 weight horns for unlimited weight).
Strive fitness Rotary Torso: A+ (modified to have 225 lb weight stack, predominantly to help make setting 2 adequately challenging).
Strength Inc. Inverted Sit Up (revision of the Old Body Master Inverted Sit Up. Designed for the Hard Core Sit Up user).
Atlantis fitness adjustable ab bench
Benches:
TOP-TIER:
Nebula Awesome utility bench
Elite FTS Collegiate 0-90 bench
Williams strength signature Military dumbbell bench
Nebula dumbbell pullover bench
Nebula flat bench that is adjustable at both sides for incline, decline, and flat of various heights.
Sorinex Autospot benches
Atlantis Fitness Autospot benches
Glute Ham Developer:
UCS Glute Ham with custom wide footplate and wide footpads (36" width footplate)
Pullover Machines:
Nautilus
Hammer Strength plate loaded (with custom pad spacers as shown in thread)
MISC:
Rogers Athletic Pit Shark
Rope machines
Power -Lift Adjustable plyo boxes
Elite FTS Swiss Bar
Black Iron Strength fat bars
Black Iron Strength attachments.
T-Grip Barbell bars and attachments
Leg presses:
TOP-TIER:
Runner-ups:
Leg Curl:
TOP-TIER:
Runner-ups:
Leg Extension:
TOP-TIER:
TOP-TIER:
Calf Machines:
TOP-TIER:
Sorinex Donkey calf
Shoulder:
TOP-TIER:
Runner -ups:
Traps:
TOP-TIER:
Sorinex Diamond Bar
Triceps:
TOP-TIER:
Biceps:
TOP-TIER:
Back:
TOP-TIER:
MedX Avenger Row
Runner -ups:
Chest:
TOP-TIER:
Runner -ups:
Abs:
TOP-TIER:
Benches:
TOP-TIER:
Pullover Machines:
Nautilus
MISC:
Rope machines
Elite FTS Swiss Bar
