Are you sure you had the proper Nagra approved batteries in the proper condition? How long could you operate it on batteries before shutting down?
I also owned the PLP and at one time the NiCd batteries were exhausted - it could not play for more than a few minutes without mains. As the distributor was on holiday, I got a 8 D cheap chargeable D cells from a shop. I could use the PLP for a few hours between charges but the sound was clearly of inferior quality even when played with the mains. Later I got the proper cells and the good sound come back. Perhaps if the PLP had a remote I would still own it ...
Edit - re-reading my my post it does not seem not clear. Please notice that the PLP should not be operated without mains - it was not designed to be operated that way. The batteries were used as filter, not to supply energy to the PLP. But if they could not stand for a about 4 - 5 alone hours they should have been replaced.
