JackD201 - Almost Done
JackD201
1,606
1,850
Manila, Philippines
It started literally as a creepy subterranean bunker....
As the rock wool and double walls came in....
then came the custom treatments and frames....
Problem is I knew I had to bring the VR-9s through these stairs down to the basement....
We don't have big guys like you have over there. So I opted to have this built instead. Should come in handy if I ever get even bigger loudspeakers....
Here they are provisionally positioned in the unfinished room. I'm still waiting on Guilford of Maine fabric that's been delayed. The garbage bags on the wall are growing on me though. Very Dark City ;)
and from some alternate angles....
The analog rig will move in once all the fabrics are up and the rugs soon after.
Thanks for looking!
Gorgeous Jack!!
That looks stunning Jack! I think I may have to do a stopever in Manilla when I visit my brothers in Vietnam next!
John
Thanks Steve and John! 20 years of dreaming and saving. I have to admit it feels REAL good! All of you are welcome should you pass by these parts. I make a mean prime rib too :)
How long did it take to get everything done up to now?
John
PS: I like my Prime Rib RARE!
About 14 months from slabs to now. The rest of the house had to be finished first. You know, Dad comes last ;) The HT was up weeks ago. Shoot! I should take pics and post that too shouldn't I? I promised es347.
120 deg F Center cut, you got it ;)
Congratulations! It looks truly stunning...
Now that's room treatment!
Thanks again guys!
Gavin, I wanted a fireman pole but the wife figured I might have a Natalie Portman look-a-like dancing on it ala Closer if she wasn't around ;)
For those that PMed, the chair is an Auckland by Cassina. The headrest can be brought down to shoulder height (I'm 5'10") so I can do my William Shatner impersonation or up around the head so I can do my Adam West. It feels and smells like a GT drivers seat. I highly recommend it to those looking to be comfortable but not fall asleep at the wheel of a turntable spinning at 45rpm.
Greg, my father always told me "Do it once, do it right". So I decided on a ground up build. I ended up tearing down the old house my wife and I bought and built under and over it. The ceiling slab is cantilevered and has only one cross beam. Dimensions wise I picked out prime numbers to avoid multiples. The dimensions are 3m Height (finished...damn beam!), 7m width 11m length (slab to slab). Never saw this in any text books, most charts generated are for 50sqm or less. The idea of using prime number dimensions just seemed so right I gambled. I figured the Lyngdorf could cover me since there are no early reflections other than the floor anyhow. Turns out there is a 230V RP-1 for sale cheap if anybody wants mine. The result is no suck outs in the bass. Modal distribution is in the 3 digits frequency range ;) Noisefloor is below 30dB with the AC running. I'm running ducts 35% larger than standard specs for low velocity. The rest of the acoustics I left to the professional acoustician who did our recording studios and soundstages. Besides, he's leaps and bounds better than I ever was so that too seemed the logical thing to do. I'll post measurements when everything is done and I get the 4 mono blocks matched properly. The bass amps need some attenuation.
What I didn't make provisions for was for isolation transformers. My brother had been telling me to do it but for some reason I shrugged it off. Now that I've opted to go straight into the wall and floor lines, orphaning my V-Rays. I'm regretting that.
Next big step is the lighting. Inside the Onyx bar are the DMX controllers for the LED cove lights and 4 Martin Alien 05s will be transplanted from my old listening room a couple of clicks away. The wave will also be backlit.
Back to eBay to hunt down more LPs :)
That is fantastic. I hate you. :)
Prime numbers are a great way to minimize room modes and most studios and many other spaces use that approach. I did plan that for my media room, until we added/enlarged a basement bedroom and the volume came out of my HT room. Now, I have a few nasty humps...
30 dB noise floor is outstanding!
We (maybe just I) badly need a great big green "envy" emoticon... - Don
We all need that big green envy emoticon Don! Steve's pre and amps, Myles' record collection, Ron's prog CDs, Mike's Rockport, Albert P's Coral Stone, all those R2R and TP tapes, oh the list goes on and on! This is WBF after all! Important thing is it's not real envy and that we're all happy for each other :)
Just say when Mullard, Let's have Jadis over also. :)
Hi JackD201,
Let's schedule after the Lamm M1.2 amps are set-up. May I bring supermario when I visit you?
Sure! I can also hand him the LL2 for a check up :)
Boy, that is a nicer room than anything I would even dream about at home let alone build :). Congrats. Must put a smile on your face to show it to folks before you even turn int on :D.
How are the construction costs in Philippines? I assume much lower than states. Yes?
Oh much, much less Amir. What I spent treating and lighting this room wouldn't buy a pair of mono amps from Lamm or Spectral :)
