Have you heard Lamm?
Yep, I like it. But when driving less than efficient speakers, I get more sense of stage and "airiness" than the bass from Lamm.
I can't disagree, however on a high efficient speaker even his SET's sound quite convincing
Most tube amps, unfortunately bore me. I have only heard CAT have that driving bass.
It depends on what you call "realistic bass". If you are asking for detail in the bass, slam and depth, the Audio Research REF 750 I am listening to can be a strong candidate. Matched with appropriate speakers the Atmasphere MA2 is also a good candidate. IMHO many powerful amplifiers have impressive bass but not realistic bass, as they miss articulation and detail in the middle bass zone. Bass must be integrated with the overall performance. Many times the use of a well matched preamplifier is a key point for having "realistic bass" .
A very good post.But that is the question; I guess it boils down to what each person is after: one would like more slam, deep notes, and a fiery presentation. Others (like myself) just prefer to relax and listen .........
If you look at most tube amps they have very weak power supplies which is why they most add sweetness to the top and fail at the bottom. As far as bottom end, stick with anything that has a very robust power supply(ies) (you can always use weight as a guide). Then once you have narrowed down a few choices you can filter it down further based on the tube compliment. If you like KT-xx or EL-xx etc.
It always amazes me that people use tiny low watt tube amps on efficient speakers with big drivers expecting full grip and control....
+1
I believe the quality of the transformer has a lot to do with the ability to produce bass in a tube amp.
My ARC D70Mk2 has superb bass control, due to a robust power supply and great transformers. I have owned tube amps in the past that don't hold a candle to this amp in the bass dept...and they have produced far more power!
+1
