Complete blank slate situation!
I would recommend an over spec'd (min x2 anticipated max usage) isolation transformer of some sort with an integral wall panel system. eliminate any GFI's on these circuits. 10 gauge romex (or brand name in-wall) home runs to each Furutech NCF outlet, Furutech frame and cover. Furutech plugs. male and IEC on each PC.
ground rod according to local spec but depending on room location and soil possibly hot-rodded.
these are the basics.
..what do you think the benefit is to running 10 ga romex? Not convinced of the benefit but am sure of the PITA of working with it not to mention if it's even possible to terminate on a 20A duplex. Seems to be overkill IMO..
you are paying an electrical contractor to install the 10 gauge Romex. he/she can work with it fine and it gives proper headroom to any 20 amp circuit. not your problem it's a PITA. besides which it's going to be more solid and stiff than less robust wire and sound better mechanically.
every circuit I've ever had installed (over 20+ years) has been 10 gauge Romex and I've always been happy and never had any complaints either with the install (from the contractor) or when I upgraded duplex outlets (from my dealer).
in the context of high end systems any premium for 10 gauge Romex is trivial. OTOH JPS in-wall or other brands are significantly more spendy and that wire is very difficult to install into duplex outlets (ask Bruce Brown about that).
..not the contractor's problem...mine as I do all my own wiring (retired power EE) and IMO one would be hard pressed to actually hear a difference. But like so many aspects of this hobby regarding the minutiae, if it flaps your shutters, go for it..
Almost everything that you need to know about AC power and audio/video systems is in these three papers:
An Overview of Audio System Grounding and Interfacing
by Bill Whitlock, President Jensen Transformers, Inc.
http://centralindianaaes.files.wordpress.com/2012/09/indy-aes-2012-seminar-w-notes-v1-0.pdfhttp://centralindianaaes.files.wordpress.com/2012/09/indy-aes-2012-seminar-w-notes-v1-0.pdf
Power and Grounding For Audio and Audio/Video Systems -- A White Paper for the Real World
by Jim Brown
http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf
Integrating Electronic Equipment and Power into Rack Enclosures
Optimized Power Distribution and Grounding for Audio, Video and Electronic Systems
by Middle Atlantic
http://www.middleatlantic.com/resources/white-papers.aspxhttp://www.middleatlantic.com/resources/white-papers.aspx
IMHO you are forgetting one of the most importants for new home construction - the one about L-N twisted .
"Ground Loops: The Rest of the Story" Bill Whitlock, AES Fellow and Jamie Fox, P.E. xa.yimg.com/kq/groups/20963848/268252969/name/Whitlock-Fox+-+Ground+Loops+.pdf
BTW, I learned about this one in a post of your´s a few years ago! The mathematics and the agreement with the measurements are great .
This is one reason why JPS lab wire is a good thing.
