I find any coloration no matter how attractive that veers off neutral and natural fatiguing after a short while, often people including myself are baited by the slightly bassy and voluptuous sound specially with digital only to find out there can be too much of a good thing down the line. My suggestion is for people to stick with 2-3 tracks that they're really familiar with and know how they should sound when things are right adding variety only adds to the confusion. Ideally these 2-3 tracks should allow you to test all necessary parameters, bass level, extension and articulation, coherence, ambience, naturalness both vocal and instrumental, proper highs without accentuation, independent interplay of various instruments regarding individual scale and loudness, and of course correct tone and timbre. With very familiar tracks one should already know the strengths and weaknesses of one's system and one can see/hear if the component under test is improving or degrading more parameters. Same tracks can be used everywhere, setting up speakers or setting the VTA and tracking force of a cartridge. IMO these few tracks are as important a tool as any in one's audio toolbox, look at them as your Reference tool when testing components, setting up or educating yourself with various systems.
Not necessarily in this case and not a question of bottleneck when you're doing comparative testing, two identical wires can sound very different with different termination it's nearly impossible to figure out which is better or right with only one run and lacking a known Reference point otherwise it's just confusion.
david
Good advice. The idea is to compare to a constant known quantity and I would say to even narrow it down further to a single item,which I have said numerous times is clarity. Clarity in the context of a chorus with maybe 20 voices,you have to have some complexity. I guarantee if you can achieve more clarity listening to more complex vocal passages,you will gain performance in most other attributes. You will notice improvements in bass articulation,then try to improve the level of congestion of bass timpanys in orchestral recordings. Find good recordings and select as David says 2 or 3 tracks,using them as a constant. Comparing against a known limited quantity is a heck of a lot easier then using many recordings as a reference. This is just part of my method...it works for me....YMMV.
