What say you?
http://www.avdesignhaus.de/Analog-Laufwerk-Studie-Node_15714.html
Under the name Dereneville VPM 2010-1 created the prototype of a new tangential drive. This study will be equipped with many new features. Here are just a few:
Heavy, solid Corian chassis (60 kg), standing on air suspension feet.
Toe angle measurement by laser, Tangential linear unit with a stepper motor.
Belt drive with two frequency-controlled motors Tern EBM-Pabst.
Speed ??measurement using a pulse ring with 24,000 pulses per revolution.
Plate mass: 20.5 kg ball bearings, worn by Neodyn magnetic disks.
effective shielding due to large mu-metal layers in the dish.
Scanner-camera to the empty groove recognition, track selection via touch screen.
Gimballed special tone-arm, length and height.
Integrated digital scale at the parking position of the pick.
Balanced XLR audio output. Video output S-Video / BNC
2 built-in microprocessor controls, touch screen remote control.
Ethernet connection for easy software updates and remote diagnostics.
All parameters, such as system operating hour coverage, speeds and much more.
are always available on the touchscreen. Integrated high-resolution
Miniature camera to observe the sampling system during playback.
Completion mid 2011
Completion mid 2011
