Calibration tape
Thanks Bruce. But what the heck happened to things getting cheaper? These things are pricey.....
Amir,
MRL is the best, I usually try to buy the long version as opposed to the short tape.
Try Ebay.
Hi Rich. That's pretty good inventory! I made it to the second page. Much more to read through tomorrow! :)
Amir,
What type of calibration are you doing?
I have bought MLR tapes, but for a quick alignment at 15 ips I have also used the Tape Project calibration tape. I do not know if its available separately to non subscribers.
Pievox from Germany also sells calibration tapes at a lower price than MLR, but I do not have references on their accuracy.
http://www.pievox.de/Pegel.htm
They are sold at the German ebay
http://shop.ebay.de/pievox/m.html?_trksid=p4340.l2562
Amirm
the cheaper way is ask Ki to make one for you ether copy from a calibration tape or record from a sig-gen by one of his pro machine, once your machine match to his machine then you will play his recorded tape perfectly
tony ma
Thanks guys. I am a bit like the guy shopping for car wheels but yet, not owning a car :). I have not yet bought the deck but am researching all aspects of it.
I expect to get a used deck and like to run it through its paces to make sure it measures right. Being lucky to own an Audio Precision Analyzer, with a full suite of tape measurement tests, I can do justice to this rather than the old says of looking at frequency counter and scope. To that end, I like to get a high-quality calibration tape.
That said, I am not motivated to pay more for it than the machine will cost me :). So the suggestion of getting something from Ki might make sense.
Phone the guys at the Tape Project and see if they will sell you one. Failing that you an always subscribe to the TP and get a calibration tape free with your subscription. ;)
Oh, I didn't realize they gave you a calibration tape for free.
What is the deal with the subscription? Do they have the tapes for the past issues at hand and send them to you as soon as you sign up or do you have to wait for them to make them?
Hi Amir,
It is expensive, but :eek::
http://www.tapeproject.com/subscription/subscription.htm
Your deck will need IEC equalization (rather than NAB) to play the Tape Project Tapes.
Rich
You do get a free one with subscription. Many of the titles are sold out with only a handful of other titles lft. As for the new ones you wait til they go into production
(...) I expect to get a used deck and like to run it through its paces to make sure it measures right. Being lucky to own an Audio Precision Analyzer, with a full suite of tape measurement tests, I can do justice to this rather than the old says of looking at frequency counter and scope. To that end, I like to get a high-quality calibration tape.
If you are going to refurbish an old machine you will need an wow and flutter test tape, not included in the Tape Project tape, that has only IEC equalizing tones at 250nW/m. As far as I remember the AP also includes a scrape flutter test - do you have the "High Band" flutter option?
BTW, you should buy a Studer - it will feel at home with the Levinson's! :)
Amir, I'd like to learn more about your experience with the AP
if possible (I'm considering acquiring one)...is it a currently supported model or an S1/S2? I believe it was mentioned there was a capability to evaluate tape performance...if you have the W & F module, does it require a test tape?
I have a few MRL alignment tapes, 1/4" and 1/2", obtained from John French and the Tape Project alignment tape...they did NOT match up.
My tech advised that I establish MRL as the reference...I adhered to his advice :cool:
It is a system 2. Now that you mention it, we had no intension of measuring tape so it doesn't probably have the W&F module. I will do an inventory and report back.
Tapes are tricky things when it comes to calibration. One never knows how good they are. Some things are better in digital :).
In reading the paper come whit MRL calibration tape (choosing and using MRL calibration tapes for audio tape recorder standardization), you will find out in analog world, 0.00% accurate means nothing. in the paper said below 500hz at a tape speed of 15 in/s - there are important sources of error that make this approach inaccurate-----. when I made adjusting the record amp of Studer A80 and A810, there are only have a high frequency pot and has no LF pot for adjust and said to using the repro amp's low frequency pot to match the in put of recording. so measurement of tape machine is not same as digital system will not have a very detail numbers but compare different recorder's sound quality they all sound different even the frequency respond almost the same, so just change any parts in there include mechanical and electrical will change the sound also, that is why listening compare is the only way in tape machine which I believe
tony ma
I use the MRL tapes for the mechanical checks, such as wow and flutter, and rely on the Tape Project for other alignments, as my major (until now unique ...) source for tapes is the Tapeproject . Where did you find they do not match?
