It's not free for a small 30" display @ $48,000.00+ USA list price, but it's the best.
• https://pro.sony/en_DK/products/oled-monitors/bvm-x300-v2
Color consistent mastering monitors with all the color translators for pros? Not really necessary for consumer purposes. The rotgut OLEDs are fine enough.
I have a more modestly priced color calibrated monitor for my photography (i'm no pro, but like good tools), and a Sony 4K OLED A1E 65" in the same room upstairs in my barn.
i'll take the OLED all day for watching anything moving. the calibrated monitor is not close in way as far as enjoyment. one is a tool with a specific purpose, one is for enjoyment.
and just bought a JVC RS4500K front projector for my HT in the house. it will be installed Tuesday. looking forward to some 10 foot wide movie watching.
Congrats. I have this projector and enjoy it immensely almost every day.
Ian,
do you use the Lumagen Pro and Panamorph Paladin DCR lens? i'm trying to decide whether I need those. I love HDR on my Sony A1E and want to make sure I have sufficient brightness to make it pop. that's why I did that...…I loved how it looked and I figured if I could get that 10 feet wide i'd be all over it.
Mike, I have the Lumagen Pro, but not the Paladin. I was considering the Paladin when AVS had the special deal but the only person that I knew that had one was an AVS salesperson. I'm a nut for HDR myself extra and brightness is nice to have, but I would only employ the Paladin if I wasn't using the Lumagen to do the tone-mapping. The Lumagen converts to SDR where brightness is not an issue. I go back and forth between using the Lumagen to tone-map vs the JVC's native HDR mapping or custom curves. Because HDR is all over the map in terms of mastering, there are some titles where I prefer bypassing the Lumagen's tone mapping but I am very picky and most wouldn't notice the difference.
I also use the Lumagen as my main video switcher (my Classe SSP-800 pre/processor doesn't do 4k) as well as aspect ratio control (instead of changing lens memories to 'zoom' to each image size). My screen is 2.35:1 and 11 feet wide. When you say 10 feet wide, do you mean 16x9 (1.78:1) aspect ratio or something wider (e.g. 2.35:1, 2:40:1)?
Some of the video nutters claim that even the 5000 lumen Sony laser is only threshold bright enough for some HDR around 130" diagonal. The Sonys can be stacked up to four units and have programming to converge the images.
I personally find HDR a bit redundant even for a reasonably bright projected image. There is an ethos to projection that can be lost in the shuffle there, may as well just get a super bright direct view. It gives the philes something to cavil, ****, parse and moan over for a while, though.
my throw is only 19 feet, with 124" diag (115" x 48") on a 2:40 ratio and Studiotek 100 screen. I sit at 11 feet from my screen. which is why I'm thinking about the Lumagen Pro and the Paladin DCR lens, to add light for HDR. but right now it's only in my mind, as I have not yet personally experienced it.
with my modestly sized screen I can likely get by without those for now. but am allowing for them when I can do it.
I read that the JVC has advantages over the big Sony, especially in the screen size I use. better blacks and equal or better lens. my JVC will be in a closet so the noise is not a factor.
agree on the magical HDR on the direct view A1E.
I'm using the 203 Oppo + the Anthem AVM60 processor.....and adding the Revel C763C Atmos ceiling speakers to my 7.1 set-up.
I have a Studiotek 130 so I have more light than you even though my screen is larger. Still I think you'll be fine if you use high laser for HDR (you'll definitely want mid laser for SDR).
You are lucky Mike; Kris is a good asset.
Kris Deering (who reviewed the JVC and other's) lives locally and has helped me spec the gear, and he will do the final set-up in a month or so. I wanted a higher gain screen, but he thought overall the 100 would be best in my room for ultimate resolution from that lens.
I think projectors should play to their strengths, rather than trying to "compete" with direct view, so I don't really see HDR as being that important with them.
