Amp Stand for Vitus SS103
JayT
29
10
108
Dear friends, as you all can guess from my thread title, I have finally decided to continue sticking to Vitus for my amp!
In order to accommodate it though, I would need to move it out from my rack, and onto the floor. Obviously that's not ideal so I have been asking around for some opinions, and have shortlisted the following:
1) Critical Mass Maxxum
2) SRA Ohio Class XL + 2
3) Stacore Basic
Between the 3, does anyone have any comments? I know that it will be crazy to attempt to A/B them with an 85 kg amp, so would have to depend on the thoughts of everyone.
I am also open to other suggestions, and some friends have also asked me to consider putting them on footers, and then on to the floor. Would that approach work? Thanks in advance!
Bodhi
1,051
361
155
My friend recently took delivery of a pair of CMS Maxxum amp stands for his AF Strumento mono's. I got to hear his system when the mono's were sitting on his timber floor with no isolation & after when the Maxxum amp stands were added. After the initial settle in period of a week or two, the improvement was significant. The bass seemed to be better anchored and correctly damped, and the sound overall seemed more settled. That doesn' t mean rolled off though...when he played me good recordings, instruments were well resolved and defined & drew me into the music. I was very impressed. They seemed to remove any solid state artifice, creating a natural sound which was addictive. They're also the best looking amp stands i've seen (aside from the flagship Olympus amp stands). I now plan to use CMS isolation products when I upgrade my racks.
Also fyi, Joe Lavrencik advocates that the best solution is using both his CMS amp stands/racks and CS2 isolation feet, since the component's relatively cheap feet are the weak link between the chassis and filter. Btw, congrats on going for that deal on the SS-103. It is a great amp for sure, especially in synergy with your SL-102 pre.
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
Hi Jay,
Thank you for considering us.
It is not as crazy as it may look: Two adult persons should have no problem moving 85kg amp over a small distance from platform to platform. On our side, our US distributor Aaudio Imports will be getting two Baisc platforms soon.
Cheers,
Reactions: JayT
JayT
29
10
108
Hi Jay,
Cheers,
That might be something for me to consider. Unfortunately I'm based in Singapore where there is currently no dealer of your fine product so would have to depend on reviews for now.
bazelio
2,494
1,749
345
California
If the active isolation solution isn't the best performing of the three, I'd have to say Houston, we have a problem. Should be interesting. As Stacore says, just do the A/B with the help of a friend.
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
Apologies Jay, for whatever reason I assumed you are in US. We of course offer 2 weeks trial time but understandably the eventual shipping cost back to us being a limiting factor here.
Cheers,
tima
5,873
6,952
1,400
the Upper Midwest
3) Stacore Basic
I've had both the SRA Ohio Class XL + 2 and the Virginia Class Reference amp stands under my Lamm amps. These are made specifically for the component that will sit on them yet can be modified if you change your amp down the road. You can read about both of them (comparison) in my coverage here.
Anytime you change what a component sits on, there will be changes in resonant frequencies and likely changes in sonics. Personally I'd say forget footers as a single solution for an amp. I've tried such and yes, I heard some differences, but nothing like the improvements I hear with dedicated amp stands.
Reactions: JayT
bonzo75
22,655
13,692
2,710
London
3) Stacore Basic
You should also PM Jazzhead. He has a fantastic system with marten II and Vitus 101. He experiments a lot with ancillary equipment as that is his OCD.
Reactions: JayT
ddk
6,261
4,043
995
Utah
3) Stacore Basic
Frankly you won’t go wrong with any of these platforms, all 3 will give you ample isolation and great sound but there will be differences in the bass from each platform. None are bad and how much that matters depends on your system’s resolution but all will be better that having the amp sit on the floor.
david
Reactions: JayT and tima
