I think it is for both. It is my honour to share a batch with you Sir.
Anywya i think you need to go over board with the cable sir. Make at least 1-2 meter longer than you need so it dont put so much pressure to your post Sir.
:-D
This Kuro will take Audiocrack grounding scheme to the limit.
Tang
A few days into burning in a Kuro SilverGold Bocchino xlr interconnect. The detail and layering and dynamucs of this cable are excellent!
Thanks Tango and Gian for helping me thru the process!
I could say:
I thought I had reached the maximum (in my system) but I had not yet listened to these cables ...
I just say that a try on this cable is needed. One of the incredible thing which happened is concerning the naturalness and simplicity in the definition of music. The notes flow without any distortion and everything seems to be effortless.
I am amazed by what I listen to and tend to increase the volume more and more.
Thank you, I not use exceed, but with these new Kuro's cables there is not any hint of distortion.Congratulations, Paolo! I also have tended to increase the volume more and more with my latest changes. Just make sure you take care of your ears, it's very easy to overdo it. I bought dedicated SPL meters (iPhone apps don't work) and follow NIOSH guidelines.
For those who bought the Kuro SilveGold speaker cables, they take quite a while to break in, especially biwire ones like mine. I was not impressed at all at first day because I didnt hear a thing better than my MIT. But now they are all I ever need from a cable. I havent used the grounding scheme that came with the speaker cables. They are good as is.
What I really dont like about Kuro is they are so damn stiff and heavy putting so much stress on my rca's. You also have to buy longer length to compensate for the bigger arch required due to stiffness. This is the price for their sq.
Tang![]()
Dear Mr Tang,Emiliano of Kuro sent me a 9 meter interconnect. I opened the box and found the biggest rca connector I have ever seen. It is bigger than my thumb. I don't know what model of Bocchino this thing is.
I am using it to connect my left side amp to preamp. The other side I use 7 meters with Gold Bocchino. I don't hear abnormality using unequal length interconnects that some people worry about. No time lag no nothing. In fact this new Kuro SilverGold with big ass connector makes my system sounds even more... just music.
Kind regards,
Tang
Hello Hieukm,Dear Mr Tang,
You did not upgrade to the best Kuro geometry cable? The RCA connector looks crazy.
