Sme 3012 R
I know this old arm is good but I don’t know why David,Rockitman,Tang,Ron,Mike
Use or will use having top tonearm like Sat,EliteAxiom,Black Beauty,Durand
Why 3012 is so special?
I never had and I don’t understand
Only to know for my curiosity
Regards
Gian
Shane, it’s a different tonearm and very different cartridge for me so it’s hard to determine the contribution of each. What I will say is it blows the simplicity II + Anna +Clearaudio out of the water. May be its my personal taste which tends towards a full rich sound. Colouration is no problem for me but not something I guess I try and add. The sound is the best I’ve ever heard at home. Pitch black backgrounds, strong and powerful voices with an intimacy I didn’t have before. My Avid Acutus with SMEV and LP-S is better than the Anna combo but even without comparing I think this is my preferred combo. Now I know why the Japanese like SPUs so much. With horns this would probably be even more incredible.
Reactions: CKKeung
what´s the difference between SME 3012R and the PRO version?
best
Leif
Not a direct answer but a little more information which may be of interest.
There was another version which was called 3012-R 2203s.and has metal knife edge bearing. A few of these were built with upgraded internal wiring and were called 3012-R GTA. I bought a pair of these about 10 years ago from the original purchaser. Brian Laker at SME remembers building them himself.
Fortunately back then you could order them with the standard copper wiring and the steel bearing and forego the specially crappy silver wiring, unfortunately today your only option with SME is the silver wiring:(!
david
Eh. I've only heard maybe a couple cables with silver that were ok. Time to replace if you got silver!
David, I apologize if I asked before. Do the tonearm wires at any point pass through metal where each channel has a different hole? Isn't it plastic where the RCA cables plug in?
david
David, there are quite a few copper cables on the market. Would any of them be a suitable, albeit slightly inferior, substitute for the original SME cables?
The RCA jacks are mounted to a plastic piece
and this is how it's wired in the back. The other end of the black ground wire has a metal tab at the other end and is screwed to the inside of the arm tube.
Is this what you're asking about?
david
Yes that was exactly it. This is an advantage over tonearms/turntables that pass signal through multiple holes that are grounded.
How does the 3010R compare to the 3012R? The 3010R is on my radar for a 2nd arm because I already have the short SME arm board for the AF5.
It's nearly identical but a little lighter sounding than the 3012-R, works great with a full bodied rich sounding cartridge.
david
Reactions: djsina2
That sounds my ideal type of cartridge, which ones do you have in mind?
Does anyone know what the stock SME headshell weighs and if it's ok to use a heavier one (dimensions remain the same)? My cart seems to be 1gr short of being able to be balanced yet the effective mass of the 3010R seems perfect for it.
