Speakers for Pass Labs Electronics ?
krelldog
34
14
138
I'm all in with Pass Labs. I have the 250.8---XP 12---and my phono pre is the XP 17. I have used electostatics for over 20 years, and for the last 4 years have used Martin Logan Montis's.
As much as I love my current speakers, I'm getting the itch to transition into a non electrostatic. One of the speakers I'm considering is the Harbeth 40.2's. The problem is I really have no audio stores in my neck of the woods. Let alone a Harbeth dealer.
My question is...what speakers are you using with your Pass Labs setup? I'm really open to any and all suggestions.
Thanks in advance.
BTW- My listening room is 14x25 with a vaulted ceiling.
Magico S5 Mark II. Absolutely love them being driven with Pass 600.5 amps
Reactions: JimmyS
Reactions: Audire and shakti
And I personally use Coincident Pure Reference Extremes with highly modified (diy) First Watt F4 monoblocks. Transparent with a touch of sweetness and a beautifully holographic presentation.
My vote goes to B&W 800 Series loudspeakers.
If you haven't already, and before moving away from electrostatics, you should listen to Sound Labs. Pass Lab amps drive them extremely well. For your room size, I recommend the 645 or larger.U1:1.jpgUltimate 845
Reactions: picears and rbbert
I concur with the recommendation for Soundlabs. I have two friends who are driving these speakers with Pass X-600.5's. The sound is magnificent.
I'm driving a pair of Magico S3 MKI's with Pass Labs XA60.8 mono blocks.
Lots of Magico owners are digging this brand combo
Reactions: Audire and PeterA
Passlabs amps can work with many speakers. A friend has a pair of XS monos to drive his WAMM Master Chronosonic and a pair of X600.8 to drive the WAMM Master subsonic and previously I was using XA100.8 driving Sonus Faber Amati Futura and later SF Lilium.
"As much as I love my current speakers, I'm getting the itch to transition into a non electrostatic.'"
Did you ever make your move? If so, what did you get and how pleased are you with the move? Still using Pass Lab amps?
Something a little on the softer side since I can't stand Panasonic lytics.
Reactions: analogsa
I'm happy with MartinLogan CLX driven by Pass X250.8 and XP-22 preamp. Have not had the chance to hear other options mentioned though.
Sound Lab electrostatics and Pass Lab amps are a wonderful combination. I have both the XA-60.8 model (pure class A) and the X-260.8 amps (class A/B). I would be happy to have any WBF member visit me ( SF Bay Area) if they are interested in hearing them.
No..I'm still using my M/L Montis's. Also..Yes I am stilll using a 250.8 and an XP 12 pre.
I'm a little hesitant to make the switch given my system sounds incredible as it is.
Also...Its extremely hard to demo large floor standing speakers in my home. I also don't have any dealers in my area.
What speakers would you recommend for PASS Labs XA30.5 + XP-12 in a smaller listening room of about 12 x 18 x 8 ft, please?
Nelson Pass uses Tannoy's (among others) to test his amplifiers.
Would any Tannoy's fit? Turnberry GR at 93dB (2.83 Volts @1 metre) efficiency, perhaps?
Any and all suggestions are most appreciated.
Thank you very kindly in advance, dear experts.
No, and I probably won't. I continue to be pleased with Sound Labs after more than 25 years. I do own a dynamic speaker system (Fritz/Sequera) which was temporarily pressed into service while awaiting delivery of my Sound Lab U-545's in my city system, and they were delightful. If the need arises, I might do so again.
"What speakers would you recommend for PASS Labs XA30.5 + XP-12 in a smaller listening room of about 12 x 18 x 8 ft, please?"
I own this amp and used it with my Fritz/Sequera speakers in a similarly sized room, and the results were outstanding. Speakers with sensitivity of 95db or greater will do well with this amp.
I’m using x260.8 to drive magico s5 with a happy result.
Thank you very kindly, @MtnHam !
This requirement pretty much says No Tannoy's, no Magico's, and no SoundLab's or Quad's either... I am lost and just devastated, frankly.
Should I consider X series (97 dB 1W/1M sensitivity) from Spatial Audio? Does not look like these OB designs are popular among the experts here...
Any alternatives, please?
