Abbas dac 2.1 se
russtafarian
48
74
923
Welcome and thank you for the review.
Did you guys compare with the lampi dac?
It would be a rookie mistake not to.
Can you give examples from quboz of the distortion problems?
Another abbas user reported about something similar — but i couldnt reproduce and thought, if anything, it was the recording that was the problem.
Enjoy the Silence by Tori Amos from Strange Little Girls.
Up from the Skies by Rickie Lee Jones from Pop Pop.
Reactions: jespera
russtafarian
48
74
923
Yeah, why not compare the $2500 Abbas with the $50k Horizon? (Assuming Ron got a Horizon).
At some point Ron and I will compare my Abbas to his Baltic 4. We just haven't arranged it yet.
Reactions: jespera
russtafarian
48
74
923
charles1dad
451
576
330
69
Michigan, USA.
If there's a discrepancy here, it's likely due to my limited ability to describe what I hear. I'll try again, but if this doesn't help you, just chalk it up to me being a dumb-ass who can't use his words.
With the ESS DAC I hear lots of bright sparkly little details popping out all over the place, fighting for my attention. Consciously I perceive this as increased resolution. It sounds bigger and more exciting! I suspect that some of what I'm hearing are artifacts that confuse my mind at a subliminal level. I'm hearing music, but it's not flowing into my bones the way I want it to.
With the Abbas DAC I get less of that sparkly detail, but what I do hear punches through my conscious awareness and goes straight to the heart.
Less artifacts. More music.
Russ,
Okay, now I understand your point much more clearly, you explanation/description hits the bullseye.Highly emphasized audio details versus natural emotionally musical engagement.
Charles
cal3713
350
384
135
45
youtube.com
Hi Russ,
Quick question.
If your other DACs are missing the nuance lnflections /ebb and flow, what makes them more resolved? Why aren’t they capable of retrieving/retaining this? This would seem to suggest they are less resolved.
Charles
I was using the Logitech server OS package. I didn't try others, so I can't comment in that regard.
As you probably remember, I'm a power supply snob, so I too was impressed when I saw the new Magna Mano dual chassis version. I'm sure it sounds better, as every improvement I've ever made to a power supply was rewarded with lower distortion and more relaxed listening.
Reactions: charles1dad
jespera
494
539
200
London
Spot on.
If you want to count nose hair on the guitarist, get the ess dac.
If you want to get into the music, get the abbas.
charles1dad
451
576
330
69
Michigan, USA.
@jespera said,
“Spot on.
If you want to get into the music, get the abbas.”
Beautifully clarified and succinct.
Charles
charles1dad
451
576
330
69
Michigan, USA.
@vinhxn has recently received his Abbas 3.2 Signature DAC. I hope that he finds time to share his thoughts and listening impressions on this thread.
Charles
russtafarian
48
74
923
Yesterday I relistened to the tracks that I initially heard distortion on when I first got the DAC. No distortion now, even with Roon headroom management turned off.
Hmmm… The distortion was definitely there when we first fired up the DAC. Ron heard it too. My guess (and this is definitely a guess) is that the tube clock needs to warm up and stabilize before the SPDIF receiver will consistently lock to the digital stream.
I edited my original post to include this update.
jespera
494
539
200
London
I couldnt reproduce either.
Artnet
142
117
115
59
Melbourne, Australia.
May or may not be relevant but occasionally when rushing into CD listening the SPIDF receiver on my 4.1 wont read and have to reboot and let warm up before inserting a disk into the transport. It could be a communication thing but I like the slow down and warm up theory.
vinhxn
7
9
3
53
Hey Everyone,
I guess I'm a member of the Abbas club now that I own a 3.2 Signature DAC. First, let me tell you my "rookie mistake" story. I did receive my DAC in mid October but I couldn't get it to work. First all I heard was static noise then it started to play half a song then stopped. I bought replacement tubes and replaced all except for EZ11 and it still didn't work. I recently bought an Audio Note M5 Phono pre-amp. While moving components around, I swapped the Abbas RCA interconnect with a different brand then holy moly the DAC started to sing. Long story short, my dog bit on the wood part of the connector when I first got the cable. There were teeth marks on the wood plug but I didn't think it "short" the cable. I removed the damaged wood plug, swapped out the cable and the rig still works :)
As for the quality of the sound, I'm not good on describing sounds. I don't have great DACs to compare against. If there's one word to describe it, I'd say it's very musical. Good music stirs up emotions and to me that's all that matters. I have someone with better ears who will come later this month to help tune the system so I'll ask him for his thoughts.
Here's my setup and I'd like to get some advice on a few things:
Source: Custom Windows-based Music Server with JCAT XE USB powered by JCAT Optimio Duo 3 and HDPlex 800W ATX LPSU
Streamer/Player software: Roon core and endpoint (mainly for usability)
DDC: Audio-GD DI20HE
DAC: Abbas Audio 3.2 Signature
Pre-amp: Audio Note M5 Phono
Amps: Bob Carver Cherry 180 monoblocks
Speakers: Marten Design Bird 2
Questions:
- Does anyone here have an amplifier built by Abbas and pairing with an Abbas DAC?
- For those who has a DI20HE DDC, do you use internal clock or external master clock? I've been using a cheap GPSDO feeding 10Mhz clock signal to the DI20HE. I'm looking for an improvement in this area so I just order a LHY OCK-2 master clock.
- Does anyone connect an Abbas DAC to their amps directly? Abbas mentioned that he does not use a pre-amp when he tunes his products. 4.5V RMS is plenty to drive the amps. My problem is with volume control. I'd have to use Roon DSP volume to attenuate the signal and I really don't want to apply additional filters unless I have to (to keep the signal as pristine as possible). Note that the Abbas DAC is NOS so high resolution files would have to be down-sampled by Roon. Connecting the 3.2 Sig DAC to the Audio Note M5, the music gets really loud at just a quarter volume.
Reactions: Artnet
djsina2
1,172
1,018
243
I use two different TVC (passive pre) instead of an active preamp. It works great with the Abbas high output voltage.
charles1dad
451
576
330
69
Michigan, USA.
@vinhxn,
“ If there's one word to describe it, I'd say it's very musical. Good music stirs up emotions and to me that's all that matters.”
Agreed, this is the most important and cherished attribute an audio component can offer. If it doesn’t connect and engage you with the music, why bother? The music should come alive, be expressive and thoroughly stimulate one’s emotions to the music they are listening to.
@vinhxn , if you have very limited volume control range before sound becomes too loud, this suggests excessive gain of your audio system.
Your Audio Note M5 (And or the power amplifiers) are likely high gain level components. 4.5V output from the DAC is pretty high. I asked Abbas to make my output voltage 3.5 (Which he did).
My current Yamamoto DAC has 3.2 v and this is fine in my system. My Coincident Line stage has 10 db of gain. Speakers are 94 db sensitivity. Volume control settings usually between 11 to1 oclock with most recordings.
Charles
Reactions: Artnet
jespera
494
539
200
London
I use a modded icon audio la4 pre. After modification it has two outputs: one with amplification and one with just a single valve buffer stage. I use the latter.
As for feeding the dac: i use roon to downsample to max 48khz/24bit. With normal 44/16 cd material this means just straight pass through. With 96 and 192 khz “hires” it just means roon needs to send every second or fourth bit word. So a very simple operation. The spdif receiver chops from 24 to 16 bits.
Abbas does a valve clocked usb-spdif converter which i use and like. He also does separate valve clocks which you could probably use with your ddc.
charles1dad
451
576
330
69
Michigan, USA.
@jespera
How well do the hi resolution recordings sound down sampled via the DAC?
Charles
trinley
43
45
125
Duesseldorf
@Artnet sorry I didn't respond to your last PM. I was waiting for Abbas' answer and wanted to let you know about it. Abbas didn't answer for almost two weeks. I wrote him again shortly before the New Year.
Because it may interest others, I report here somewhat about it.
The power grid does not work at the moment, the diesel generator had also given him problems in recent weeks. Abbas writes that he also had to be a master of the generator :D
About a week ago, a missile was shot down over his house. The fragments hit about 15m from his house.
He writes that he and his family are doing well.
About my 3.2 Signature he writes, that the thicker case of higher quality and all other components have arrived. Mounting has already started.
As soon as I know more, I will report here.
