Videos of Acoustically-Coupled Audio Recordings
Yes the main thing that matters is which one sounds more natural, that's number 1 IMO and I am attributing the unnaturalness in 2 & 3 to the mics.
1 and 2 used the same mic (iPhone internal mic)
The question is not more or less natural the question is which one sounds like Ron’s system if you are sitting there in the room?
Of course, you are correct, and we can't know that, which is why it is best to use higher quality recording equipment...
But we can also try to make an evaluation of the end result compared to the original track. If that were not the case, would you (or anyone else, including myself) be posting videos on YouTube?
My only reference, as a viewer, is to compare the video to the original track.
It is a very difficult excercise, and I think I was very careful in pointing out potential limitations of the recordings (of all three videos).
The MV88+ video reasonably fairly represents the in-the-room resolution I hear. The iPhone mic video reasonably fairly represents the tonal balance I hear in the room.
I, personally, find the David/Tang speaker video to be comparatively low in resolution and transparency. Peter, I hear that it is rich and warm and fulsome in the upper bass to lower midrange frequency range. It has a sonic center of gravity in the "power" range that I find emotionally engaging and unfatiguing.
I think the treble range is shaved down. For this reason I find the sound to be unbalanced.
I don't understand how you find that video abundant in "information" and "nuance."
I have learned from my objective in room frequency response measurements alone the wide gap between objective measurements and perceived subjective frequency response balance. (The frequency response of my system drops off sharply after 5kHz, yet the system subjectively sounds flat and neutral and leaning towards brightness. I think it would be extremely illuminating to see a carefully measured frequency response of your system/room or of Tang's system/room.)
Reactions: Scott Naylor
Once again, it is really unfortunate that we don't have frequency response measurements for these microphones. The specs (usually state 20hz-20khz) are pretty useless. Reviews of these microphones are usually geared towards different applications (speech) so not so useful either.
Here is one link with some measurements, illustrating why it is important:
Yes:
This is measuring an old iPhone model. I can't imagine that if David and I have an iPhone that is no more than one (1) generation apart that the microphone frequency response is going to materially different.
One could assume that, but similar "older" models have discrepancies, so who knows ?
I just found this site which does offer some measurements of various phone's build-in microphones: https://www.dxomark.com/category/audio-reviews/page/2/
Concerning the iphone14, it states here (https://www.dxomark.com/apple-iphone-14-plus-audio-test-result/): "The differences between the iPhone models when it comes to audio playback and recording have usually been minimal. The same holds true now with the release of the iPhone 14 series"
But I think this is only valid for recent models. Also, in their tests, the FR graphs don't go very low in the frequency range.
Here is a detailed review of the iphone 13 pro:
"As a recording device, the 13 Pro Max delivers a very good timbre performance. The rendition is natural, warm, and rather consistent, with an emphasis on the lower midrange.
Unlike in playback, recordings have a darker sonority due to a receding high-end extension and limited treble. As a result, brightness is dimmed, and vocal intelligibility is altered. In noisy surroundings, such as our urban scenario, conversations have a hard time standing out of the background noise. This problem is less noticeable in high-SPL scenarios, in which the phone demonstrates clear, precise, rich and consistent midrange, a better high-end extension, and powerful bass — without ever sounding boomy.
In life videos, memos and meeting scenarios, the phone’s frequency response generates a slightly muffled sonority with subtle resonances in the lower midrange. That said, the overall result remains natural and pleasing."
Notice this comparison between various recent phone models:
The graph does not indicate how low bass is measured (in some other graphs they stopped at 100hz). You can see 10db differences between phones on some frequency ranges, which is significant.
Edit: here is another graph for the iphone SE 2022 model, which has a reasonably flat frequency response (build-in mic). You can see the graph stops just below 100hz.
Not debating that…questioning if the Shure is the right tool for the job…
Yes:
Which is precisely why I put forward the iTestMic2 in that any inconsistency between disparate chipsets , circuits and mic’s across iphone and Android are rendered moot, and we might have that ’standardisation’ talked about , the hardware at least.
We don't share the same values.
I too find that recording lower in resolution and dare I say muddy . Voice and what is being sung is not so easy at times to clearly hear. Is the tone nice? Yes but at least as recorded it throws the baby out with bath water. Tone and dynamics, sure, but there also needs to be transparency and resolution…the other way around(more common in high end) is also not good as it comes across as analytical and unnatural.
Reactions: Argonaut
I think your judgement here is clouded by the idea you have of what the systems should sound like, and perhaps even by Ron's own comments on his video which need to be taken with a grain of salt as he is not - correct me if I am wrong - listening with headphones
Given the poor quality of the video 1, I don't see how you can say that it sounds more natural (unless you think colored sound is more natural).
Once again, I was not criticizing Rexp, I was just trying to offer explanations... Why are you being so insistent about this ? Did I offend you in some way ?
Fwiw, I was responding to Scott.
I will try to be patient here.
It's quite simple. You were critically "explaining" why someone else had the view that he did. You don't have access to another's thoughts or motives.
Telling Rexp his judgement is clouded by his idea of what he thinks the system should sound like is a direct criticiism, an ad hominem description.
I don't see how one can conclude that video 1 is more "natural sounding" than 3. The sound quality of the recording of video 1 is bad, there is echo, coloration, etc.. comparing with the original track played from Qobuz makes it very clear.
You did not understand my earlier remark and thought I was talking about LPs. I never mentioned an LP. Here you make an appeal to something streamed from Qobuz saying video 1 did not sound like that and apparently -- my guess -- videos 2 and 3 sound more like what you heard streamed from Qobuz. A far better 'argument', or at least an explanation of why you have your view would be to say "I'm judging these videos based on what I hear from Qobuz, (presumably through headphones); that is my standard." At least that explains your opinion and let's readers assess the value of it from that explanation.
Reactions: PeterA
