All NEW Add Powr Sorcer X2 Power Conditioner....Major Breakthrough In Electrical Power Conditioners!
It appears that Onepoint5 confuses the Sorcer's technology with something completely different.
The analogy to ifi ANC is flawed simply because Sorcer does not filter AC line noise and intereference.
It is not injecting any high frequency signal onto the AC line like the anti harmonic inductrial devices you describe.
The proprietary technology of algorithm digital defined power or ADD-Powr adds harmonic energy to the audio/video/analog/digital signal. This is
Desctription of the technology is provided at www.add-powr.com. This is not a white paper. It offers a simple explanation and assertion of the claims made. '
Essentailly, the comcept has nothing to do with audio but everything to do with the quality of AC power employing principles of the Fourier series, resonance, and electromagnetic field theory.
Test data and graphs are available showing audio signal increase by as much as .25-.50 dB in strength with the Sorcer.
This is easily corroborated by acoustical power level measurements taken from an audio speaker system using white/pink noise input signals.
Thanks for the link, I watched the video.
This statement is from the FAQ on the site:
Why are multiple transformers used in the Sorcer?
Multiple transformers create large electromagnetic fields that can be used to effectively propagate our low frequency algorithms. They are also an effective low impedance interface to the AC line. The harmonic resonator effect is maximized using several connected in series.
When there's a low impedance, there needs to be something that measures and injects a resonant frequency to make this happen, you can't just guess. Anyway the amount of LEDs switching on and off on the insides surely is a point of adding switching noise. The board layout reminds me of construction used in the 90's.
Also
What is ElectraClear?
ElectraClear is not a filter. It is a harmonic resonator that induces a programmed range of pulsed frequencies onto the AC line, clocked from the original 50 or 60 Hz waveform. These harmonic overtones impact the low and middle audio range, so as to harmonize or tune the sound.
There is a drop in the noise floor and a commensurate increase in the qualities of image depth, dimension, and realism in audio and video signals and systems
This device actually adds harmonics to the AC line. Effectively tube gear would be a better option.
These products are well engineered, and was curious how they worked but their application is in the land of the fairies. Not convinced.
Also
There is nothing, no resonant frequency, that is being injected onto the AC line whatsoever.
Fine, switching LEDs on and off is meaureably insignificant, especially if it is not interfaced with any small signal, i.e. audio.
That's fine. The board layout is more than adequate for what the circuitry needs to accomplish.
Again, may I remind you that this technology is not a power conditioner.
If you want to know more about how the product works read about it at the site.
Many engineers are stuck in thinking in a closed, conformist philosophy. indeed,the assertions and claims made will blow many minds!
The concept is based upon principles of physics. The proof is in the pudding.
Out-of-the-box thinking is what drives ADD-Powr® technology and its development.
The problem is that tube gear is ineffective in saturating the entire signal path with harmonics.
ADD-Powr continues what tubes do.
Suit yourself.
This technology has more relevance to electronics and communication systems than you can imagine.
Suit yourself.
You need to put a disclaimer in your signature that you are the principal at Add Power.
