Which is the best SFP GPON module for Fritzbox 5590 fiber?
engadin
342
250
135
63
SFP modules obviously do sound different when used for streaming.
The module in the Fritzbox 5590 fiber needs a sfp module with
ITU-T G.984.2/984.5 GPON
LC/APC 8°
TX 1310nm RX 1490nm with Filter
rogue detection
0.5 - 5 dBm (sending)
-3 up to -28dBm (receiving)
20km
SFF-8472
laser class 1
Has anybody swapped SFP GPON modules in a Fritzbox?
Which of the higher end say Finisair modules would meet specifications?
Finisair distributor ARROW … does not know.
Finisair I did ask, still waiting for an answer.
Thx a lot for your comments!
One of these:
He needs an SFP with embedded ONT, as was mentioned. This is GPON protocol between Fritz and the provider, not Ethernet. Highly doubt changing this will have any impact on sound.
gotcha, misread & sorry about the wrong info.
LC/APC 8°
rogue detection
20km
SFF-8472
laser class 1
I did look info different sfp modules for my Fritz!box het. They are encoded.
haven't found ome het , the connectors on the one I'm using seem to be deccent enough.
I have to check which connectors I need, thanks!
Reactions: audiophilac1
Perhaps the SC/APC cable can be changed. Mine's SC/APC. Recently ISP here rolled out GPON
my 5530 shows following spec for GPON, lc/ apc, wonder of that is not the same for 5590
FRITZ!SFP GPON​
  • geschikt voor ITU-T G.984.2/984.5 GPON
  • LC/APC 8°
  • Golflengte: TX 1310 nm, RX 1490 nm (met filter)
  • Geschikt voor rogue detection
  • Zendvermogen: 0,5 tot 5 dBm
  • Ontvangstbereik: -3 tot -28 dBm
  • Bereik: 20 km
  • Ondersteuning van SFF-8472
  • Laserklasse 1
I ordered the corning!
I did, I skipped the regular converter cable so have to double check anyhow.
