I think I used this to renew some rubber TT belts. How do you use this on dampers, other than carefully?
Slowly and carefully apply small dabs of it with a needle until the bushing is completely covered.
Nobody is going to sell you a Koetsu Black at your price point. I have a Grado Sonata 3 that has less than 250 hours on it that I would be happy to sell you. PM if interested.What I would like to do is find someone who could sell me a used low mileage Grado Sonata or Koetsu Black at a reasonable price.
I like both flavors of TK-7, one more brash the other more delicate.I find it to be brighter as well. But I have always wondered if there is a stylus profile that gives us only positive improvements with this cartridge.
Didn't know it was by Excel, tho that makes sense. The other one I have is an A&R Cambridge, not as good SQ, but maybe because of age. The elliptical Shelter stylus is engaging, but the SAS has more snap, more HF info, sounds more like an MC--my preference--as you'd expect given its cut.I am a fan of this old Excel body that even bore the name Supex. I can still buy these new for as little as $130 new from Japan. The Shelter iteration may be the best yet.
Do you not like it with the stock stylus? What improvements does the SAS bring, and what are the negatives?
May I know what tonearm you are going to use with the upcoming cartridge? Do you have multiple tonearm for different compliance cartridge? And what is your phono preamp? All these elements would significantly affect your cartridge choice.........I has been looking for a vintage cartridge that is warmer, smoother and more forgiving than my current cartridge, a very transparent and revealing (but not overly bright) Signet TK7e.
This cartridge must also be musically involving, with nothing that will overtly detract from its engagement.
I believe that the original Koetsu Black, classic Ortofon SPU series, and several of the top stereo cartridges made up to 1965 produced the general type of sound I am looking for, but I also require an unfailing level of high frequency purity and refinement that most vintage (and modern) cartridges fail to possess (my ears are very sensitive to it).
If I had the money, there are a few top end cartridges that may suffice (I like the Air Tight Opus). But I am very poor these days, and would like to find a used cartridge that gives me this level of "musical" refinement for under $500.
I have been looking at the Supex SD 801/901 series, but don't know if they can deliver enough of the above requirements to significantly better my Signet, which is about as good as a vintage MM cartridge that I have heard, despite being rather unforgiving of less than perfect recordings.
The Grace 707 is only good for high compliance cartridge, such as the MM, some MI and light weight high output MC. The MA101 is not really a high mass tonearm, but MA77 can categorize as mid to high mass when comparing to MA-101.I currently use a Grace 707 II, but I have also been looking at higher mass tonearms such as the Micro-Seiki MA77/101.
For all these vintage tonearm, the internal copper wiring most likely oxidized or at least the soldering point require overhauling to restore it performance, IMHO, you better have these used tonearm rewired before setup on your TT.
Have you ruled out oldies such as Empire (EDR9, 2000) or Shure V15 -III or Pickering 5000? Probably difficult to find, but very rewarding.Also, I now own an MS 101 tonearm, so I am more flexible in the cartridges I can use.
I have been gifted a Shelter 201 to play with for now.
