And how would you test that...
Now I'm curious..
The testing from my side is in the asking of the question 'Which DAC?'' to Mike.
Now I'm curious..
This is my contention as well based on what I think I know about signal processing, not much I must say:0
I would like an honest discussion on the subject so that to answer some questions, among these:
Why so much energy into developing SACD
Why is it that some people maintiain it sounds better than PCM? I am assuming identical mastering, a really overly optimistic assumption but ...
Listened to various RBCDs which have used 1bit systems (both bitstream and DSD) in the recording process. I hear what Stanley Lipshitz talks about in his paper (just cited above) - noise modulation. Have not listened to DSD128 but see no reason why it would be different as its still just a 1bit system which Lipshitz shows is fundamentally flawed.
Its not my opinion here, its the contents of my perception - listening. Theory says it can't work, practice shows it doesn't in fact work. So the two are in harmony.
Well I'm curious here - what DACs are you using to listen to RBCD on? My hypothesis (which I'm more than willing to test right here) is that your chosen DACs aren't doing justice to the RBCD material.
Mike,
It seems you have a very valuable asset. Can you tell us something about the system that was used to digitize these RTR master tapes?
I hope that you good backups of these files, but I think that for increased safety you should keep a backup in a small country of western Europe.![]()
As far as I know (but I may be wrong, I hope that the experts will debate this aspect) the big issue with DSD is that there are no mastering tools in DSD - the DSD recordings are converted to analog or PCM for mastering. Recording in pure DSD must be something like recording a direct cut LP.
Its one possibility, another is that the CDs I've listened to which had DSD mastering on them were flawed. Tell me more about your MSB DAC before I jump to any too-hasty conclusions. How do you use it - what sample rates do you feed it and what sample rates is it using internally? How does it handle both RBCD and DSD in terms of its internal structure?
i use the Playback Designs MPS-5 for discs and for my server dac. my server feeds PCM, dsd, and 2xdsd to the dac thru USB. the PD uses a programmable dac designed by Andreas Koch . i'm quite happy with my RBCD performance.
i would ask whether you have any high quality analog sources in your system to actually compare to how RBCD and dsd sound in your system compared to that source. all the theory in the world still needs to be proved by listening.
The MSB is a ladder DAC.
For PCM, the best results were with upsampling on, to 32/352, and the default 32x filter.
I've asked the designer (Larry) whether the DSD signal is converted to PCM, and he claims it's not, neither in the transport, or inside the DAC. It's native DSD.
Interesting indeed, and still catering to all needs, the listener is left to make up their mind.
Worthwhile mention I think, as one can get a file in a variety of formats for comparative listening.
As the question of this was too tenderfooted for a sideline in the CES report, here's a thread.
Has anyone seen any statements from the music industry that they are going to supply less dynamically compressed mastering on this format, or is it just another smoke and mirrors trick
for all but a very few special pressings? Current trend isn't positive with new releases of Beatles/Beach Boys etc that's less dynamic than previous releases, even if they are claiming to be gentle with the source.
Can we expect better transfers from old mastertapes and better new masters than with the current 10-12dB crest dynamics, that EASILY fit the CD format and then some...
My hypothesis then is that your DAC isn't doing justice to RBCD's dynamics - you're missing out. Andreas Koch last time I read about him had drunk deeply at the well of DSD koolaid. I'd not want him as the designer of my RBCD DAC.![]()
No I don't have any analog sources whatsoever in my home, let alone in my system. When DSD sounds so obviously inferior to RBCD, wouldn't a high quality analog source make DSD sound yet worse?
have you listened to any of his designs?
No, I haven't. If you give me a good reason to seek them out though, I might be interested. What does he bring to the table which is innovative for RBCD replay?
I take it its a proprietary design, no off-the-shelf DAC chips being used?
That's contrary to my own experience on RBCD where the best results have been obtained with the lowest sample rates. I'm a NOS devotee. I conjecture you're getting appreciable noise modulation by virtue of running so fast. The presence of noise modulation means a less dynamic sound.
What's Larry using for the DSD 1bit DAC element? Is he willing to share?
