4x4 Music room setup advice
EoltheDarkelf
1
44
Switzerland
Hello everyone!
I have a room that I currently use as a music room (I play hand drums), but also as an office and for other leisure activities. It's about 4x4 m in size, but has two sloping ceilings running the entire length, reaching a height of 1.90 m on one side and 1.20 m on the other. The roof/ceiling surfaces are paneled, the walls are plastered, and the floor is laminate.
There's no furniture yet, except for a fairly substantial desk. I've planned to put Ikea Kallax on the higher long wall to store my sheet music and books, small instruments, maybe a few folders, office supplies, etc. My drums (3 congas) are also in there.
Now I'd like to install a music system in there so that I can, firstly, practice/play along to music and, secondly, simply listen to music. My main genres are Latin American music (salsa, son, etc.) and hard rock/metal. It's okay if it gets a little louder now and then (single-family home). I do like having a decent sound, but I wouldn't call myself an audiophile.
However, I still have no idea what to buy. What's worth it given the room dimensions, what makes sense? First, regarding speakers – 2.0? 2.1? Passive speakers and amplifiers? A complete active system? Where/how do I best set them up?
But also: How do I get the music on there? I do have CDs that I might store in the room, but I don't want to be messing around with them all the time. The main source for "my" music is MP3s on my Synology NAS. If I spontaneously want to listen to something that I don't have in my collection, I look for it on YouTube. I don't have streaming, but it should be possible to play something like that. And of course, it would be good to be able to connect to the system via Bluetooth.
I'm a Windows person with an open source leaning. I'm not completely untalented when it comes to DIY and technology (I work in IT), but I have little knowledge of hi-fi and sound engineering. I can certainly invest a couple of evenings into it, but I don't want it to degenerate into a 100-hour DIY project. My desired cost for the system would be around €300, with a pain threshold of €500. However I'm not 100% committed to this budget yet, si if i learn more my vision might evolve...
And I have a collection of old speakers from music systems that could be used (but don't have to be):
2x Jamo K-25
2x Sony SS-J20
2x Philips F9218L/50Z
1x AIWA SX-NAVH80
Thanks for your thoughts, suggestions, spontaneous ideas, etc. I'm also happy to answer any further questions about the room, the existing technology, my requirements, etc.
Best regards
The only issue with your room is going to be the perfectly square dimensions, since certain frequencies will create standing waves between the parallel walls. The sloping ceiling does help though. You'll have to play around with the positioning of the speakers and the listening position until it sounds right. This will likely be the most important thing to get good sound in your room.
For 300 eur it may not be worth building a passive speaker system. I'd start by looking at active speakers with everything built-in, as it's most cost effective.
You should also consider just getting good computer speakers, since the computer will act as the source/streamer. For example, the Ruark MR1 is great: https://www.ruarkaudio.com/products/mr1-desktop-speaker-system and within the 500 eur budget.
Of course you can go the separate components route as well and assemble a system out of second hand parts, starting from one of your existing speakers, but it's more of a "project".
