What a disappointment Rainer...
Now you're just one of the 'mob'.....I see nothing new here.
You are kidding me, I think.
my second Player is still under development and construction.
And while developing this second Record-Player, (the Dereneville Direct-Drive from 2012) I found the way to this brandnew Tangential-Tonearm.
It is an universal, computer programmable, HighEnd-Tonearm - yust the best in the world.
It works fully automaticly, is controlled by a rotary encoder, has a turnable display and is equipped with the latest electronic on bord.
The tonearm itself is gimbal mounted and can move free in all directions. and the base ist continiously moved, to get less than 0,01 degree angle.
You can dial: homeposition - 12" - 10" - 7" or center for inside-out-cut or you can move it maually, as you like.
Is that disappointing you?
Another example is my new and latest, universal final drive unit for a lot of turntables all around the world.
But listen: it is computer progammable via USB-connection. You can make 3 setups, you can increase in speed and also decrease in speed-
-just tepends to the weight of the platter. You can programm Motion-Animation means: turning you turntable for just one minute.
Every 12 hrs. or 24 hrs. or 48 hrs. what ever you like (if you are on vacation or hollyday, you can be shure, the oil and the string/belt will be moved)
And now, my friend, are you still disappointed? If so, I can't help.
A last few words to this new record player: the platter has 25 kilogramm, is 100 % magnetic beared, there is absolutely no noise anymore.
The feet of the plinth are adjustable and have a specially absorbtion tecnique inside. It is prepared for vacuum clamping and direct drive.
Thats all I want to say to my new creations...
And to my dear friend Steve: yes, I'm going to manufacture and to sell my latest babys.
But only made by honestly order
And all together, this tools are named: Dereneville Modulaire
http://www.hifistatement.net/event/item/1638-analog-forum-krefeld-2015-teil-1
http://www.avdesignhaus.de/AnalogZubehoer-Node_15748.html
http://www.avdesignhaus.de/AnalogLaufwerkbau-Node_15750.html
Bye for now folks, I have to count my money
and please no more hard tecnical questions - my english is too bad.
Rainer
